Another button to the attribute inspector?
2540
6
10-18-2013 07:21 AM
ionarawilson1
Is it possible to add another button to the attribute inspector (There is a delete button already) with the editor widget sample?
<!DOCTYPE html> <html>   <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">     <!--The viewport meta tag is used to improve the presentation and behavior of the samples        on iOS devices-->     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">     <title>Edit rivers and waterbodies</title>      <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">     <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css" />     <style>       html,body{height:100%;width:100%;margin:0;overflow:hidden;}       #map{         padding:0;       }       #header{         font-size: 1.1em;         font-family: sans-serif;         padding-left: 1em;         padding-top:4px;         color:#660000;       }       .templatePicker {         border: none;       }        .dj_ie .infowindow .window .top .right .user .content { position: relative; }       .dj_ie .simpleInfoWindow .content {position: relative;}     </style>          <script src="http://js.arcgis.com/3.7/"></script>     <script>       var map;              require([         "esri/map",          "esri/toolbars/edit",          "esri/layers/ArcGISTiledMapServiceLayer",         "esri/layers/FeatureLayer",          "esri/symbols/SimpleMarkerSymbol",         "esri/symbols/SimpleLineSymbol",          "esri/dijit/editing/Editor",         "esri/dijit/editing/TemplatePicker",          "esri/config",         "dojo/i18n!esri/nls/jsapi",          "dojo/_base/array", "dojo/parser", "dojo/keys",          "dijit/layout/BorderContainer", "dijit/layout/ContentPane",          "dojo/domReady!"       ], function(         Map, Edit,          ArcGISTiledMapServiceLayer, FeatureLayer,         SimpleMarkerSymbol, SimpleLineSymbol,          Editor, TemplatePicker,         esriConfig, jsapiBundle,         arrayUtils, parser, keys       ) {         parser.parse();                 // snapping is enabled for this sample - change the tooltip to reflect this         jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start +  "<br>Press <b>ALT</b> to enable snapping";                 // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html         esriConfig.defaults.io.proxyUrl = "/proxy";              //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.          esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");                  map = new Map("map", {            basemap: "satellite",           center: [-96.541, 38.351],           zoom: 14,           slider: false          });          map.on("layers-add-result", initEditor);                 //add boundaries and place names          var labels = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");         map.addLayer(labels);          var rivers = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/1",{           mode: FeatureLayer.MODE_ONDEMAND,            outFields: ['*']         });          var waterbodies = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/0",{           mode: FeatureLayer.MODE_ONDEMAND,            outFields: ['*']         });          map.addLayers([waterbodies,rivers]);          function initEditor(evt) {           var templateLayers = arrayUtils.map(evt.layers, function(result){             return result.layer;           });           var templatePicker = new TemplatePicker({             featureLayers: templateLayers,             grouping: true,             rows: "auto",             columns: 3           }, "templateDiv");           templatePicker.startup();            var layers = arrayUtils.map(evt.layers, function(result) {             return { featureLayer: result.layer };           });           var settings = {             map: map,             templatePicker: templatePicker,             layerInfos: layers,             toolbarVisible: true,             createOptions: {               polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],               polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,                 Editor.CREATE_TOOL_CIRCLE,                 Editor.CREATE_TOOL_TRIANGLE,                 Editor.CREATE_TOOL_RECTANGLE               ]             },             toolbarOptions: {               reshapeVisible: true             }           };            var params = {settings: settings};               var myEditor = new Editor(params,'editorDiv');           //define snapping options           var symbol = new SimpleMarkerSymbol(             SimpleMarkerSymbol.STYLE_CROSS,              15,              new SimpleLineSymbol(               SimpleLineSymbol.STYLE_SOLID,                new Color([255, 0, 0, 0.5]),                5             ),              null           );           map.enableSnapping({             snapPointSymbol: symbol,             tolerance: 20,             snapKey: keys.ALT           });                myEditor.startup();         }       });     </script>   </head>   <body class="claro">     <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">       <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">         Edit Hydrography       </div>       <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">         <div id="templateDiv"></div>         <div id="editorDiv"></div>       </div>       <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>     </div>   </body> </html>
JasonZou
Here is the revised code.
<!DOCTYPE html> <html>   <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">     <!--The viewport meta tag is used to improve the presentation and behavior of the samples        on iOS devices-->     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">     <title>Edit rivers and waterbodies</title>      <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">     <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css" />     <style>       html,body{height:100%;width:100%;margin:0;overflow:hidden;}       #map{         padding:0;       }       #header{         font-size: 1.1em;         font-family: sans-serif;         padding-left: 1em;         padding-top:4px;         color:#660000;       }       .templatePicker {         border: none;       }        .dj_ie .infowindow .window .top .right .user .content { position: relative; }       .dj_ie .simpleInfoWindow .content {position: relative;}              .esriAttributeInspector .atiMyButton {   float: left;   margin: 0px;    }            </style>          <script src="http://js.arcgis.com/3.7/"></script>     <script>       var map;              require([         "esri/map",          "esri/toolbars/edit",          "esri/layers/ArcGISTiledMapServiceLayer",         "esri/layers/FeatureLayer",          "esri/symbols/SimpleMarkerSymbol",         "esri/symbols/SimpleLineSymbol",          "esri/dijit/editing/Editor",         "esri/dijit/editing/TemplatePicker",          "esri/config",         "dojo/i18n!esri/nls/jsapi",          "dojo/_base/array", "dojo/parser", "dojo/keys", "dojo/_base/Color", "dojo/dom-construct", "dojo/dom-class", "dijit/form/Button",         "dijit/layout/BorderContainer", "dijit/layout/ContentPane",          "dojo/domReady!"       ], function(         Map, Edit,          ArcGISTiledMapServiceLayer, FeatureLayer,         SimpleMarkerSymbol, SimpleLineSymbol,          Editor, TemplatePicker,         esriConfig, jsapiBundle,         arrayUtils, parser, keys, Color, domConstruct, domClass, Button       ) {         parser.parse();                 // snapping is enabled for this sample - change the tooltip to reflect this         jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start +  "<br>Press <b>ALT</b> to enable snapping";                 // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html         esriConfig.defaults.io.proxyUrl = "/proxy";              //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.          esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");                  map = new Map("map", {            basemap: "satellite",           center: [-96.541, 38.351],           zoom: 14,           slider: false          });          map.on("layers-add-result", initEditor);                 //add boundaries and place names          var labels = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");         map.addLayer(labels);          var rivers = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/1",{           mode: FeatureLayer.MODE_ONDEMAND,            outFields: ['*']         });          var waterbodies = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/0",{           mode: FeatureLayer.MODE_ONDEMAND,            outFields: ['*']         });          map.addLayers([waterbodies,rivers]);          function initEditor(evt) {           var templateLayers = arrayUtils.map(evt.layers, function(result){             return result.layer;           });           var templatePicker = new TemplatePicker({             featureLayers: templateLayers,             grouping: true,             rows: "auto",             columns: 3           }, "templateDiv");           templatePicker.startup();            var layers = arrayUtils.map(evt.layers, function(result) {             return { featureLayer: result.layer };           });           var settings = {             map: map,             templatePicker: templatePicker,             layerInfos: layers,             toolbarVisible: true,             createOptions: {               polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],               polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,                 Editor.CREATE_TOOL_CIRCLE,                 Editor.CREATE_TOOL_TRIANGLE,                 Editor.CREATE_TOOL_RECTANGLE               ]             },             toolbarOptions: {               reshapeVisible: true             }           };            var params = {settings: settings};               var myEditor = new Editor(params,'editorDiv');           //define snapping options           var symbol = new SimpleMarkerSymbol(             SimpleMarkerSymbol.STYLE_CROSS,              15,              new SimpleLineSymbol(               SimpleLineSymbol.STYLE_SOLID,                new Color([255, 0, 0, 0.5]),                5             ),              null           );           map.enableSnapping({             snapPointSymbol: symbol,             tolerance: 20,             snapKey: keys.ALT           });             var newButton = new Button({label: "My Button"}, domConstruct.create("div", null, myEditor.attributeInspector.editButtons, "first"));        domClass.add(newButton.domNode, "atiMyButton");           myEditor.startup();         }       });     </script>   </head>   <body class="claro">     <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">       <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">         Edit Hydrography       </div>       <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">         <div id="templateDiv"></div>         <div id="editorDiv"></div>       </div>       <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>     </div>   </body> </html>
JasonZou
ionarawilson1
Thank you so much Jason! This is awesome. Can you please tell me what I am doing wrong? When I try to add it to my code my app does not show anything. Thanks
 require([
        "esri/map", "esri/toolbars/navigation", "dojo/_base/connect", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
       "dijit/form/ValidationTextBox",  "esri/toolbars/edit",
  "esri/tasks/query", "esri/tasks/QueryTask",
        "esri/config",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
  "dijit/layout/AccordionContainer",
        "dojo/dom", "dojo/on",
        "dojo/domReady!",
      ], function(
        Map, Navigation, connect, BasemapGallery, arcgisUtils, ValidationTextBox, Edit,
  Query, QueryTask,
  borderContainer, contentPane, titlePane, AccordionContainer,
        dom, on
        parser.parse();
ionarawilson1
Duh! I forgot to add a comma after Button! By the way, do you how we can increase the width or the height of the attribute inspector? Thank you so much!!!
JasonZou
ionara, you just posted this thread for changing the width and height yesterday. It does not work any more?
ionarawilson1
Hi Jason,
It does work, but I was curious if there is another way to do this, perhaps using CSS.
JasonZou
Calling resize() might be the easiest way. Controlling the popup size via css is not easy and may not be a good idea since different feature layer may have different set of attributes which will require the popup able to adjust its size dynamically.
