Popup Mobile for dynamic map service layer
1058
10-09-2013 05:23 AM
francescodi_vito
Hy guys,
i have a question.
Is it possible to use the popup mobile for a ArcGISDynamicMapServiceLayer?
In the example it works with a webmap and i tryed with infowindow lite but with this i have some error; with infowindow lite the dynamicmapservicelayer don't load.
francescodi_vito
hello guys,
I'm developing a mobile application with jQuery Mobile API and javascript. I have followed the example of the popup mobile but does not work on dynamic mapservice that i use.
Any thoughts on this? Can you give me some advice?
This is my code.
[HTML]
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9, IE=10">
<meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
<!-- API JQUERY MOBILE -->
<link rel="stylesheet" href="themes/geologia.min.css" />
<link rel="stylesheet" href="http://code.jquery.com/mobile/1.3.2/jquery.mobile.structure-1.3.2.min.css" />
<script src="http://code.jquery.com/jquery-1.9.1.min.js"></script>
<script src="http://code.jquery.com/mobile/1.3.2/jquery.mobile-1.3.2.min.js"></script>
<!-- API ESRI JAVASCRIPT -->
<link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
<script src="http://js.arcgis.com/3.7/"></script>
<link rel="stylesheet" type='text/css' href='http://serverapi.arcgisonline.com/jsapi/arcgis/2.3/js/esri/dijit/css/Popup.css'/>
<style type="text/css">
  html, body
        height: 100%;
        margin: 0px;
        padding: 0px;
        width: 100%;
   #mapcontent, #map { width: 100%; height: 100%; padding: 0; position: absolute; z-index: 0;}
    </style>
<script>
var map;
var layer1;
var popup;
    require([
      "esri/map",
      "esri/dijit/BasemapToggle",
      "dojo/domReady!",
   "esri/layers/ArcGISDynamicMapServiceLayer",
   "esri/dijit/Popup",
   "esri/arcgis/utils",
       "esri/dijit/PopupMobile",
    "dojo/dom-construct",
    ], function(
      Map, ArcGISDynamicMapServiceLayer, arcgisUtils,
          Popup
      popup= new esri.dijit.Popup(null,dojo.create("div"));
      map = new Map("map", {
        center: [12.785, 42.372],
        zoom: 6,
  slider:false,
        basemap: "topo",
  infoWindow: popup
/*aggiungi layer*/
    layer1 = new esri.layers.ArcGISDynamicMapServiceLayer("http://www.pcn.minambiente.it/arcgis/rest/services/geologica/MapServer",
    visible:false}
map.addLayer(layer1)
function updateLayerVisibility() {
  var isChecked = $('#checkbox-v-2a').is(':checked');
  if(isChecked == true){
  layer1.show()
  else{
  layer1.hide()
</script>
</head>
<body>
<!-- home view -->
<div data-role="page" id="home">
  <!-- header -->
  <div data-theme="a" data-role="header" data-position="fixed">
  <a href="#toc" data-role="button" data-icon="star" data-iconpos="notext"></a>
    <h3>Geologia</h3>
  </div>
  <!-- content -->
  <div data-role="content" id="mapcontent">
    <div id="map"></div>
  </div>
</div>
<!-- layer view -->
<div data-role="page" id="toc">
  <!-- header -->
  <a href="#home" data-role="button" data-icon="back" data-iconpos="notext"></a>
    <h3>Layer</h3>
  </div>
  <!-- content -->
  <div data-role="content">
    <form>
    <fieldset data-role="controlgroup">
        <legend>Vertical:</legend>
        <input type="checkbox" name="" id="checkbox-v-2a"  onClick="updateLayerVisibility()">
        <label for="checkbox-v-2a">Carta Geologica 1M</label>
        <input type="checkbox" name="checkbox-v-2b" id="checkbox-v-2b" onClick="updateLayerVisibility_1()">
        <label for="checkbox-v-2b">Carta Geologia 500K</label>
        <input type="checkbox" name="checkbox-v-2c" id="checkbox-v-2c">
        <label for="checkbox-v-2c">Operation Layer 3</label>
    </fieldset>
</form>
  </div>
</div>
</body>
</html>
[/HTML]
Hello to all
thanks
JonathanUihlein
First thing that I noticed is that your require statement is wrong.
 require([
      "esri/map",
      "dojo/domReady!",
   "esri/dijit/Popup",
    ], function(
          Popup
Should be something like:
require([
 "esri/map",
 "esri/dijit/Popup",
 "dojo/domReady!",
],function(
 Map,
 BasemapToggle,
 Popup,
 arcgisUtils,
 PopupMobile,
 domConstruct
The modules and their namespace declarations need to be invoked in the same order.
Your modules are being matched with the wrong namespace declarations. For example, you are matching ArcGISDynamicMapServiceLayer with  "esri/dijit/BasemapToggle", and Popup with "esri/layers/ArcGISDynamicMapServiceLayer".
Please read this article for the 'Hows and Whys':
http://dojotoolkit.org/documentation/tutorials/1.9/modern_dojo/
JustinFultz
Could you please post your final working code. I am struggling with this same thing, and as someone completely new to JavaScript and with little programming experience in general, I could really use some sample code to work from. Unfortunately, the documentation for the mobile popup only includes an example of using an ArcGIS.com map service.
Justin
