Transfer Fields between feature classes
4806
10-08-2013 08:19 AM
RyanWoehl
Is there an easy way to take the fields from 1 feature class and transfer those fields to a different feature class?  I don't want to do a batch "Add Field".  With all the domains it will take me a lot of time.
DarrylKlassen
This might not be the most elegant way of doing it, but if you totally want to avoid the AddField route to solve the issue, you can (in ArcMap) do a join on the 2 feature classes on any 2 fields (of similar type) and then export the feature class.  This will give you all the fields of both feature classes in the newly exported feature class.
RichardTruong
If I don't have any similar fields, but do have similar type from the two feature classes (Polyline), can I still perform the methods?
DarrylKlassen
I believe this is where you would want to do a spatial join!
RyanWoehl
That will will work for what I'm doing.  Thanks
