Error loading versions
2907
10-07-2013 03:43 PM
KarenWitsell
Greetings,
I have just upgraded to 10.1 and orginally I had editing rights to the an SDE connection (which has not been upgraded) but now when I select the version manager, nothing happens. ?  Also, when i select the change version I get the following error: "Error loading versions. [An item with the same key has already been added.]
Are these errors the result of an incompatability between 10.1 and 10.0 with regards to database connections? Is there some other reason that would cause this?
Karen
EmadAl-Mousa
can you please clarify ......what is your ArcGIS Desktop version you are using and what is the version of your geodatabase ?
Remark: if you are using ArcGIS 10.1 Desktop create a fresh new connection (don't use the previously stored 10.0 connection).
KarenWitsell
I was upgraded from 10.0 to 10.1.
The error message that I was having, was related to a need for a service pack. Specifically, I have a (.) in my user name. This may have been the cause of the error.
Here is what I found on the following site: http://support.esri.com/en/content/known-issues#version101
04/25/13 �?? Issues when SQL Server user names contain special characters such as a dot (.) or a hyphen (-).(Patch Available)
Product(s) Affected:
ArcGIS for Desktop, ArcGIS Engine, ArcGIS for Server
Version:
10.1 SP1
Bug ID's:
NIM082739 - Failure to create a new layer or table, access an existing one, or add it into ArcMap if the SQL Server user name includes a dot (.), hyphen (-) or any other character that requires delimiting.
NIM082947 - Cannot modify or delete a version created by a user with a dot (.) in the user name.
NIM083805 - ArcGIS Desktop is unable to connect to the geodatabase version if the username of the owner of that version contains a dot (.).
NIM088882 - SQL Server only: An error is encountered when creating a child or grandchild version when the version owner has a dot (.) in their name.
NIM089772 - If the connected user's name contains a dot (.), copy-paste of a feature class can fail with a 'Column Index Already Exists' error.
Knowledge Base Article:
N/A
Patch:
Released 04/25/13 http://support.esri.com/en/downloads/patches-servicepacks/view/productid/66/metaid/1980
