create new raster from attribute field
10312
10-04-2013 01:42 AM
victorianaipal
Dear all,
I have a global raster with an attribute table where some attribute fields are joined fields from another table. I want to create a new raster from one of the other fields in the attribute table. Does anyone know how to do it? (Lookup doesn't do the job, I have a 1-band raster file).
For more information its the Harmonized World Soil Database (HWSD) data (raster file with attribute table)
victorianaipal
So I found out how to do it:
So first you join the table with attributes and the global raster. Then you export this joined grid to a new grid so that the attribute table of the new raster file has all the joined attribute fields. Then there is a command in spatial analysist, reclass toolbox, called Lookup. There you use the new joined grid and then choose the attribute field you want to export as a new raster.
by Anonymous User
Not applicable
this helped, thanks
TatianaKharitonova
Thanks for your lifehack! Ten years passed it's still no better solution
KodaiYamamoto
This helped my process of HWSD. Thank you.
