Anyone has build a JavaScript API Viewer ?
1337
10-03-2013 11:07 AM
JoseSanchez
Hi all
have you built a JavaScript viewer and are currently using it?
  - did you start from scratch?
  - did you use any of the JavaScript templates
  - did you use any github templates
  - did you use any ArcGIS Online templates download them modified them and then upload them
  - did you use the AMD style
  - any other approach?
Thank you for sharing
SunilPalkar
-We used github templates and customized it at our end.
-ArcGIS Online templates are also good but it has limitation
Hi all
EzequiasRodrigues_da_Rocha1
Palkar
Have you already changed the map id (webmap) from an ArcGIS Server instead of an AGOL?
Sincerely
Ezequias Rocha
JoseSanchez
What are the limitations of ArcGIS Online?
Which github template do you recommend?
thanks
