Basemap Gallery errors?
1427
10-01-2013 01:07 PM
JessicaKnight1
I have tried to add in the basemap gallery and get this error when I add in the code:
"Error: Permission denied for <file://> to create wrapper for object of class UnnamedClass" No errors if this code is commented out. Any thoughts?
KenBuja
MVP Esteemed Contributor
Can you post the code that you're using?
JessicaKnight1
Using this example: https://developers.arcgis.com/en/javascript/jssamples/widget_basemap.html
I get the error when this section of code is active:
 //add basemap gallery
   var basemapGallery = new esri.dijit.BasemapGallery ({
    showArcGISBasemaps: true,
    map: map
   },  "basemapGallery");
   basemapGallery.startup();
   basemapGallery.on("error", function(msg) {
    console.log("Basemap Gallery Error: ", msg);
KenBuja
Take a look at this page on setting up a development environment.
When developing with the ArcGIS API for JavaScript, a web server is  required. This means that web pages and apps using the ArcGIS API for  JavaScript need to be accessed over http://  (or https://) rather than file://. To meet this requirement, install  and configure a web server. Web server software is available free of  charge for all operating systems.
