highlightMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 22, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,255,0]), 2), new Color([255,255,0,0.5])); var popup = new Popup({ markerSymbol: highlightMarkerSymbol, fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,200,0]), 2), new Color([255,255,0,0.50])) }, dojo.create("div")); map = new Map("mapDiv", { infoWindow: popup, basemap: "topo", center: [-92.593, 38.5], zoom: 7 });
Solved! Go to Solution.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no"> <title>testing</title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css" /> <style type="text/css"> html, body, #mapDiv { padding: 0; margin: 0; height: 100%; } </style> <script src="http://js.arcgis.com/3.7/"></script> <script> require([ "dojo/ready", "dojo/parser", "dojo/dom-construct", "dojo/_base/Color", "esri/graphic", "esri/map", "esri/dijit/Popup", "esri/geometry/Point", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol", ], function( ready, parser, domConstruct, Color, Graphic, Map, Popup, Point, SimpleFillSymbol, SimpleLineSymbol, SimpleMarkerSymbol ) { // Variables var map; var highlightMarkerSymbol; var popup; // Set up popup = new Popup({ titleInBody: false },domConstruct.create("div")); map = new Map("mapDiv", { infoWindow: popup, basemap: "topo", center: [-92.593, 38.5], zoom: 7 }); highlightMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 22, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,255,0]), 2), new Color([255,255,0,0.5])); ready(function () { // parse the fully loaded DOM parser.parse(); //do stuff map.on("click", function(evt){ // remove old graphics from map map.graphics.graphics.forEach(function(g){ if(g.visible == true) map.graphics.remove(g); }); // create simple symbol var point = new Point(evt.mapPoint.getLongitude(), evt.mapPoint.getLatitude()); var graphic = new Graphic(point, highlightMarkerSymbol); // add the graphic and show the popup map.graphics.add(graphic); map.infoWindow.setTitle("test"); map.infoWindow.setContent("test"); map.infoWindow.show(point); }); }); }); </script> </head> <body class="claro"> <div id="mapDiv"></div> </body> </html>
