Can I use the esri api with require.js?
3622
17
09-26-2013 05:56 AM
DonnieHolmes
I need to use the esri API within a JavaScript app that is built using require.js + backbone + others (all are a part of a standard internal company toolkit). Does anyone have any examples of how this can be done? I have done some searching on this forum and the internet in general and can't seem to find any concrete examples of how to make this happen.
I should clarify that I have tried to make this happen and can't seem to prevent the AMD loaders from stepping on each other.
Thanks.
Donnie Holmes
derekswingley1
The short answer is no, you can't use requirejs next to Dojo. If you're using Dojo, use Dojo's module loader.
JonathanUihlein
I'm sure you saw: http://requirejs.org/docs/dojo.html
Which leads to: https://bugs.dojotoolkit.org/ticket/15616
Since the ticket discussed there is resolved, it should be possible.
Some great comments further down; they should lead you in the right direction.
DonnieHolmes
Thanks - I did see that. However, I'm very new to dojo and I'm not sure which comments are relevant. I require a little more hand-holding at this point. 🙂
JonathanUihlein
Spent another few minutes on Google, found this:
http://stackoverflow.com/questions/17475515/using-requirejs-with-dojo-1-9-1
You need to use the source/SDK version of the Dojo Toolkit. Built copies of AMD modules are not compatible between loaders.
Hope this helps.
derekswingley1
DonnieHolmes
Hope this helps.
Thanks. So, it sounds like you cannot use another loader with the esri api at the moment because it is a "built" version of dojo. I guess that means I'll need to use the dojo loader or nothing. That's disappointing. Hopefully this changes in a future release.
derekswingley1
What does requirejs do that you can't do with the Dojo module loader?
DonnieHolmes
  My problem is that we have a company-internal toolkit that includes a handful of require.js plugins that are to be used as part of our web client "standard". It means that, unless there is some quick and easy way to make these same plugins work with dojo, it's going to be very hard for me to integrate an esri map into apps that are built with our in-house toolkit.. Being new to the game, I don't know if that's even feasible yet.
derekswingley1
Have you looked at using Dojo's loader to load your require plug-ins? I'm not sure if they're compatible but it's worth trying:  http://livedocs.dojotoolkit.org/loader/amd#plugins
What do your current requirejs plug-ins do?
DonnieHolmes
Thanks, I'll take a look. It looks like the plugins mostly read in external files as text, css, etc.
