How to find Begin and End points of a polyline using Arcgis  Javascript
6501
09-26-2013 05:07 AM
viteboardviteboard
Hello All,
Can anyone say how to get the starting and ending points of a polyline when we draw using Arcgis Javascript api.
Using WebAdf we are having the facility of MapLineEventArgs.BeginMapPoint and  MapLineEventArgs.EndMapPoint.
I want to perform few validation basing on this start and end coordinates of polyline
Thank You
Aravind
JasonZou
You can use polyline.getPoint(pathIndex,pointIndex) function to get the point you need. For instance,
First point of the first path:
polyline.getPoint(0,0)
Last point of the first path:
var lastIdx = polyline.paths[0].length - 1;
var lastPnt = polyline.getPoint(0, lastIdx)
viteboardviteboard
Thank you..It solved my problem.
JasonZou
Glad to help. Please consider mark your thread as "Answered" so other people may find it helpful. Thanks.
JohnGrayson
Esri Alum
Careful, the previous solution assumes the geometry is a single-part polyline, which seems to be ok for this use case, but might not work in all situations, like when the geometry is retrieved from an external source like a Map or Feature Service.
var lastPartIdx =  polyline.paths.length-1;
var lastPntIdx = polyline.paths[lastPartIdx].length - 1;
var lastPnt = polyline.getPoint(lastPartIdx , lastPntIdx);
