date output format
1304
6
07-01-2010 02:05 AM
AlessioDi_Lorenzo
Hi all,
when I execute a query against a mapservice i get dates in this format:
Mon Jun 28 00:00:00 CEST 2010
using jquery I'm able to format it as dd/mm/yyyy
My question is:
is there a way to translate the date directly into the query?
Something like:
// Query
myQuery = new esri.arcgis.gmaps.Query();
myQuery.outFields = ["ID","NAME","TO_CHAR(DATE, dd/mm/yyyy)"];
myQuery.where = "1=1";
thx
AdamPfister
what you've shown there is not possible i don't think.  if you want it coming in directly as a formatted date i think your only option is to create a new field and calculate it from the DateTime field as text in whatever format you need.   then you can specify that new field in your outFields list.
AlessioDi_Lorenzo
mmm... yes, it works but it is still a workaround (even if better than the javascript one...) and I was looking for a native solution 🙂
Thanks anyway
OT
In my opinion esri's js apis is a good tool but it has to be improved from the point of view of the query management. At least ORDER BY and GROUP BY clause and the DISTINCT selection have to be supported!
AdamPfister
awesome.  i had no idea you could inject SQL in that way.
derekswingley1
You can, but it's kind of hacky and dependent on what is supported by the underlying data source. I would still format the date with JavaScript.
hayaticm
have you found the solution?
mine is coded this way:
layerDefs[0] = "ZON='DATE = TO_DATE('"+ (dojo.byId('DATE').value) +"','YYYY-MM-DD')";
AlessioDi_Lorenzo
thank you, but using the google extensions apis I prefer jquery to dojo.
Formatting date with javascript is quite simple in jquery also:
$.format.date(attribute["FIELD_NAME"],'dd/MM/yyyy')
So, I was looking for something different from a javascript workaround but at the moment - if I understood well - it is not possible.
