Get map in Web_Map_as_JSON format in JavaScript
2921
09-20-2013 02:07 PM
HaoHu
I was trying to export map using Export Web Map Task, but I don't know how can I specify the map object in Web_Map_as_JSON format. Anyone has solutions? Or is there a better way to export the map(including all types of layers)?
Thanks!
JasonZou
The map object is included in PrintParameters object which will be fed to PrintTask for execution.
require([   "esri/map", "esri/tasks/PrintTask", "esri/tasks/PrintParameters", ...  ], function(Map, PrintTask, PrintParameters, ... ) {   var map = new Map( ... );   var printTask = new PrintTask( ... );   var params = new PrintParameters();   params.map = map;      printTask.execute(params, printResult);   ... });
You can also use Print dijit to print map. Here are some samples.
JasonZou
HaoHu
Thanks Jason, your code really helps!
JasonZou
Glad to help. If you think your question has been answered, can you mark your thread as "Answered" so other people may find it helpful? Thanks.
HaoHu
Sure thing!
