Application not showing data
2572
14
09-19-2013 04:49 AM
JohnByrne
I have created an online map and from that I created a application as well. The URL is:
http://www.arcgis.com/apps/SimpleMapViewer/index.html?appid=7ea1de5470d24298bec4d07645cf0ee0&webmap=...
On the system it works great and pretty muc how I would like apart from I would like the user to be able to do a postcode search!! However when I look at it on an ipad etc it fails to load the vector data and just loads the bas map data.
Any ideas?
TimWitt
John,
this is how it works:
Open your mxd with the shapefile you want to upload. Symbolize the shapefile the way you want it to look, once uploaded it will keep that look.
After that do the following.
Click on "File" -> "Sign in..." and sign into your organizational account.
Click on "File" -> "Share As" -> "Share as Service" -> "Publish a service"
Choose My Hosted Services (My Account) and as Service name use for example Auto_Data
In the Capabilities tab uncheck Tiled Mapping and check Feature Access.
In the Item Description tab fill in the required fields.
Once you are done with that, click on Publish
Let me know if you have any more questions!
TimWitt
Are you using an organizational account or a free account?
JohnByrne
Hi Tim, its and organisational account, (I think). You advised us on a different issue last week, and the web app is the advice you gave.
TimWitt
John,
when I open the app I can't see your layers either. Areyou host the layers with an Arc WebServer or did you upload the layers to your organizational account?
JohnByrne
I just added my service from my own server, is that the issue?
TimWitt
If it is a ArcGIS Web Server you can do it, you might just need to adjust the security settings. if it is just a local ArcGIS Server then anyone outside of your company won't see the data. That might be the issue why you see it on your desktop but not on your ipad.
JohnByrne
Its the latter I think Tim.
TimWitt
Since you have an ArcGIS organizational account, can't you just upload the data through ArcGIS Desktop and then add it to your map, that you use in your app?
JohnByrne
I will try adding it as zipped shapefiles rather than the service, is that what you mean?
IanWittenmyer
Based on the developer console error ( in chrome press ctrl+shift+I)  it looks like your assumption is correct.  I can reproduce what you are seeing and for me the solution was to fully qualify the domain of the server.  for example my server would be on the esri.com domain so if your server was on the same domain as mine, the url you would add to the webmap would be:
http://ndbc-vgis.esri.com:6080/arcgis/rest/services/NDBC/Bin_Routes_Sept13/MapServer/
