Application not showing data
4264
14
09-19-2013 04:49 AM
JohnByrne
I have created an online map and from that I created a application as well. The URL is:
http://www.arcgis.com/apps/SimpleMapViewer/index.html?appid=7ea1de5470d24298bec4d07645cf0ee0&webmap=...
On the system it works great and pretty muc how I would like apart from I would like the user to be able to do a postcode search!! However when I look at it on an ipad etc it fails to load the vector data and just loads the bas map data.
Any ideas?
TimWitt
John, you can do that too. But if you do it through ArcGIS Desktop, if you have an organizational account, you can determine the symbology yourself and don't depend on what ESRI has available.
Let me know if you need help with publishing it through ArcGIS Desktop.
JohnByrne
Tim,
I would really appreciate that, this is all new so any help is valued.
Ian,
I had a look at the developer console error you mentioned and as the screen grab shows, I don't think its as you say it should. Any tops on how to remedy that is appreciated as well.
[ATTACH=CONFIG]27617[/ATTACH]
TimWitt
John,
this is how it works:
Open your mxd with the shapefile you want to upload. Symbolize the shapefile the way you want it to look, once uploaded it will keep that look.
After that do the following.
Click on "File" -> "Sign in..." and sign into your organizational account.
Click on "File" -> "Share As" -> "Share as Service" -> "Publish a service"
Choose My Hosted Services (My Account) and as Service name use for example Auto_Data
In the Capabilities tab uncheck Tiled Mapping and check Feature Access.
In the Item Description tab fill in the required fields.
Once you are done with that, click on Publish
Let me know if you have any more questions!
JohnByrne
Thanks, legend!!!
TimWitt
No problem Brian!
Btw I can see the data now 😉
