Draw Toolbar onDrawEnd firing twice
1969
09-16-2013 09:37 AM
BrianBeck
New Contributor III
I have a simple editing application with the following code:
startEditing : function(template) {      var drawingTool = template.template.drawingTool;      switch(drawingTool) {         case FeatureTemplate.TOOL_POINT:             drawingTool = Draw.POINT;             break;         }      on(this.drawingToolbar, "draw-end", lang.hitch(this, this.createFeature, template));      this.drawingToolbar.activate(drawingTool); }
and
createFeature : function(template, evt) {      var featureLayer = template.featureLayer;     template = template.template;      var prototype = template.prototype;      var geometry = evt.geometry;      var graphic = new Graphic(prototype.toJson());     graphic.setGeometry(geometry);      this.initAttributes(graphic, featureLayer).then(function() {          var features = [graphic];          featureLayer.applyEdits(features).then(function(addResults) {             var objectIds = array.map(addResults, function(addResult) {                 return addResult.objectId;             });              var q = new Query();             q.objectIds = objectIds;              featureLayer.selectFeatures(q).then(function(features) {                 main.openForm(features);             });         });      });  }
Using a point tool with the drawing toolbar, I am finding that when I click a point on the map, the createFeature function is called twice resulting in 2 features being created with the same geometry.  How can I stop the draw toolbar from creating 2 features?
JasonZou
Occasional Contributor III
Move below statement out of startEditing function. I don't know what will trigger to call startEditing. But every time it's invoked, onDrawEnd event handler will be defined one more time, which makes createFeature invoked one more time.
I would recommend to define the onDrawEnd event handler in the same function where drawingToolbar instance is created so to ensure it's been defined once only.
JasonZou
BrianBeck
New Contributor III
Thank you Jason.  I also just realized that I was creating the onDrawEnd handler multiple times.  The startEditing function is called each time a selection is made in the templatePicker.  That means that if the user selects another template, I get a duplicate handler.  In my case, when I was testing I was selecting a template and adding a new feature.  Then I unselected the template which calls the stopEditing function.  My stopEditing function simply deactivates the drawingToolbar.  I have added code to save the onDrawEnd handler to a variable and then the stopEditing function can remove that handler when it is called.
