'where' parameter is invalid on query on feature layer
7124
8
09-10-2013 05:54 PM
PeterHudson
Hi everyone,
it has been a week that I have this problem.
I haven't changed anything on my code but 1 week ago I received a "'where' parameter is invalid" error when this query is executed on a feature service (hosted on Arcgis online):
var statDef = new StatisticDefinition();
  statDef.statisticType = "sum";
  statDef.onStatisticField = "Area";
  statDef.outStatisticFieldName = "Tot Area";
  var query = new Query();
  query.returnGeometry = false;
  query.where = "Area>0";
  query.outFields = ["Area"];
  query.outStatistics = [ statDef ];
  query.groupByFieldsForStatistics = ["YearEstabl", "TypeName"];
  query.orderByFields = ["YearEstabl", "TypeName"];
  var qt = new QueryTask("http://services1.arcgis.com/Mpa25zPNMAT08GQg/ArcGIS/rest/services/AllPropertiesEstablished/FeatureServer/0");
  qt.execute(query, function(result){
I am referencing to //js.arcgis.com/3.6/
Any ideas?
Thanks in advance!
VinayBansal
I tried running the query using Rest API interface using
http://services1.arcgis.com/Mpa25zPNMAT08GQg/ArcGIS/rest/services/AllPropertiesEstablished/FeatureSe... in browser.
Even there where parameter is giving same error you are getting in your code when using with outStatistics
Don't know why it is not accepting the where clause, as Rest API documentation http://resources.arcgis.com/en/help/rest/apiref/ says that
When using outStatistics the only other parameters that will be used are groupByFieldsForStatistics, orderByFields, text, time, and where.
JasonZou
To use outStatistics, the layer has to support Statistics. The layer you are querying does not support it. Here is one feature layer that supports it. Look for Supports Statistics: entry.
VinayBansal
Hi Jason,
But the statistics is working on this layer......if we run query without passing the where clause......
Check the attachment.......
JasonZou
It seems like spaces are not welcomed for outStatisticFieldName.
Try to change:
To:
statDef.outStatisticFieldName = "TotArea";
JasonZou
Interesting. This sample does use where clause for the statistical calculation, and it works. The main difference I can tell is the sample uses a feature layer that supports statistics, while rokitmaps uses a feature service.
VinayBansal
Yes Jason, not seeing any other difference, other than Supports statistics......
So rokitmaps, atleast you can give it a try by setting SupportsStatistics true for the layer.....
PeterHudson
From here I can see that "supportsStatistics" : true. In fact it worked before.
The query works without the StatisticDefinition. Anyway, I had to rewrite my code and do the group by manually... 😞
VinayBansal
You can try by accessing the mapservice as MapServer instead of FeatureServer.....
