Sort datagrid numerically
6022
9
09-06-2013 07:25 AM
AdrianMarsden
Honored Contributor
Hi
I'm failing to sort a datagrid, that has results from a query task, numerically.
There is a field, that the service has defined as an integer, however it gets sorted in the datagrid as text (so I get 1,10,11,12,2,21,22 rather than 1,2,10,11,12,21,22)
I have tried adding a formatter on the grid like
        function PAOFormat(item) {                         var link = Number(item) + 0 ;             return link;         }
But that fails - changing it to Number(item) + 100 does indeed add 100- to the number, so how do I tell it to be a number cell.
I have seen there is a celltype property, but I can't find a full list of cell types the best I have found is
cellTypeThe type of cell in the column. Allowable cell types include
  • dojox.grid.cells.Bool
  • dojox.grid.cells.Select
Any ideas?
ACM
JasonZou
Prior to
        //Create data object to be used in store         var data = {             identifier: "OBJECTID",             label: "LSData",             items: items         };
Go through the items loop, and convert the item attribute in need to number. Here is a sample.
var fldNameConvert = "fldConvertion"; var newItems = dojo.map(items, function(item) {     var newItem = dojo.clone(item);     newItem[fldNameConvert] = parseInt(newItem[fldNameConvert]);     return newItem; });  var data = {      identifier: "OBJECTID",      label: "LSData",      items: newItems };
JasonZou
Try:
     return dojo.string.pad(item, 3);
Have you considered to switch to the new data grid, dGrid? It's much better in terms of the performance and functionality. Here is the link for lots of examples.
Other useful links:
http://www.sitepen.com/blog/2011/10/26/introducing-the-next-grid-dgrid/
http://dojofoundation.org/packages/dgrid/tutorials/hello_dgrid/
AdrianMarsden
Honored Contributor
Thanks, but that still sorts it
001
010
011
002
I'll check out the dgrid next work day, but this is really for the last touch to an almost finished product - the next version I'll look at new stuff + making all AMD.
The results are actually from a find results set.  Is there any way that I can sort that object based on an attribute before it gets attached to the data grid?
Cheers
ACM
JasonZou
ok. I see what's happening. The formatter function only affects how the data presents in the data grid. The sort operation still uses its value, not the returned value from the formatter function. Obviously, the values you tried to sort are the type of string. What I would suggest is to convert all the values to numbers before feeding the data into the data grid, so the data grid recognizes the values are number types, and will sort them like that.
AdrianMarsden
Honored Contributor
Yep - I think I'd got to the same conclusion, however that's where my skills end.
The grid is defined so -
 <table dojotype="dojox.grid.DataGrid" jsid="grid1" id="grid1" autoheight="10" rowsperpage="160" rowselector="10px">
                        <thead>
                            <tr>
                                <th field="Address" width="160px">Address
                                </th>
                                <th field="PAO_FROM" formatter="PAOFormat" width="160px">PAO_FROM
                                </th>
                            </tr>
                        </thead>
                    </table>
and then later populated like this
        var data = {
            label: "LSData",
            items: items
        //Create data store and bind to grid.
        store1 = new dojo.data.ItemFileReadStore({
            data: data
        console.debug(store1)
        dijit.byId("keycontainer").selectChild(dijit.byId("results"));
        grid1.setStore(store1);
with items being the results dataset from the find task - however, right from when I view the attributes of the results it appears like
  • PAO_FROM: Array[1]
    • 0: "19"
    • length: 1
despite the service definition stating
  • PAO_FROM ( type: esriFieldTypeSmallInteger , alias: PAO_FROM )
AS mentioned in the first post,  I did find some reference to  cellType when creating the dojodatagrid, but no fll list of types.
Cheers
ACM
VinayBansal
There is field called comparatorMap in the data store object so you can change the sort behavior.
have a lok into this link
http://www.ibm.com/developerworks/web/library/wa-aj-dojogrid/index.html
AdrianMarsden
Honored Contributor
Thanks- I found that last week, but couldn't follow it - I'll have another go now.
JasonZou
Prior to
AdrianMarsden
Honored Contributor
🙂 Looks good - I'll try it tomorrow - right now I'm having fun with inserting directly into unversioned SDE tables using SQL and getting me geometries and geographies all mixed up - may have to post to a different forum!
Many thanks
Edit - couldn't wait (plus SQL not working) so tried it and works, marked as answered.  Many thanks
AdrianMarsden
Honored Contributor
OK, now I had to adjust my sort - the brief was to sort on house number, but if no number then name.
So
  • 1 High Street
  • 2 High Street
  • 11 High Street
And for named properties
  • Aardvark House
  • Hope House
  • Zebra Cottage
So I created a hidden column that on the face of it took the house number.  However I created (with some help, see above) a formatter for this that changed the actual row DATA.
        //change the actual DATA used in the hidden colum used for sorting
        //Add a padded string of the house number to the rest of the address, so order is 001, 002,010 rather than 1,10,2
        //We then change the actual row DATA TO THIS NEW VALUE, JUST CHANGING WHAT IS DIPLAYED DOES NOT WORK
        //Return 0 just to get something there that fill no space
        function PAOFormat(item, rowIndex) {
            var rowdata = this.grid.getItem(rowIndex);
            var sortAddress = dojo.string.pad(item,3) + rowdata.Address;
            rowdata.PAO_FROM[0] = sortAddress;
            return 0;
Changing what is displayed doesn't work..
Credit to this  http://documentumcookbook.wordpress.com/2010/08/06/dojo-datagrid-combining-field-values-in-formatter... blog post for showing how to retrieve other cell data in a formatter.
ACM
