Adding Feature Layer Causes issues
1342
08-31-2013 02:54 AM
vinayb
When i create map object using ArcGISDynamicMapServiceLayer then things work fine but since i need lot of graphics and want to handle user interactions on map so i want to use feature layer to my map but when i add feature layer the browser hangs.
Please let me know what could be the issue how can i avoid feature layer from hanging my Browser.What actually happens when i add Feature Layer does the map re render with new data , what could be the issue with Feature Layer service .
My Code
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <title>Feature Layer Only Map</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="http://js.arcgis.com/3.6/"></script>
    <script>
 dojo.require("esri.map");
 dojo.require("esri.layers.FeatureLayer");
 dojo.require("esri.tasks.QueryTask");
 var map;
 function init(){
       try{
     map = new esri.Map("map");
     var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://10.32.9.106:6080/arcgis/rest/services/Administrative_Maps/World_Countries_v1/MapServer");
     map.addLayer(layer);
     var url = "http://10.32.9.106:6080/arcgis/rest/services/Administrative_Maps/World_Countries_v1/MapServer/0";
     var info_content = "<table><tr><td><b>COUNTRY :</b></td><td style='text-align:right'>${COUNTRY}</td></tr></table>";
     var infoTemplate1 = new esri.InfoTemplate("${COUNTRY}", info_content);
     var fl = new esri.layers.FeatureLayer(url, {
    infoTemplate: infoTemplate1
      map.addLayer(fl);
    var queryTask = new esri.tasks.QueryTask(url);
      //build query filter
      var query = new esri.tasks.Query();
      query.returnGeometry = true;
                        query.where = "COUNTRY='India'";
      infoTemplate = new esri.InfoTemplate("Alert", "Alert for Re-insurance");
      dojo.connect(queryTask, "onComplete", function(featureSet) {
          //alert('calling queryTask'+featureSet);
       //map.graphics.clear();
        try{
         /*var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
         alert('somethign');*/
         var symbol0 = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 0, 0, 0.9]));
         //QueryTask returns a featureSet.  Loop through features in the featureSet and add them to the map.
         dojo.forEach(featureSet.features,function(feature){
          var graphic = feature;
          graphic.setSymbol(symbol0);
          graphic.setInfoTemplate(infoTemplate);
          map.graphics.add(graphic);
       }catch(e){
     queryTask.execute(query);
     require(["dojo/on", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color", "esri/graphic"], function(on, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic) {
                    on(fl, "click", function(evt) {
                       console.log(" on click mehtod");
                        // clears current selection
                        // create new graphic with selected graphic's geometry
      alert("evt.graphic.geometry "+evt.graphic.geometry);
                        var graphic = new Graphic(evt.graphic.geometry);
                        alert("graphic "+graphic);
                        // create a new symbol for the graphic
                        // add symbol to the graphic
                        // add the graphic to the map
    } catch(e){
        console.log(" exception occured"+e);
 dojo.addOnLoad(init);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
The Rest service of Feature Layer
Display Field: COUNTRY
Type: Feature Layer
Geometry Type: esriGeometryPolygon
Description: World Countires Map (v3) with the Display field as ISO3A. No changes to the data from V1.
Definition Expression:
Copyright Text:
Default Visibility: true
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: false
Supports Statistics: false
Has Labels: false
Can Modify Layer: true
Can Scale Symbols: false
Extent:
    XMin: -179.99999999990004
    YMin: -89.99999999990001
    XMax: 180.00000000010002
    YMax: 83.66549107605236
    Spatial Reference: 4326  (4326)
Drawing Info:
    Renderer:
        Simple Renderer:
        Symbol:
            Style: esriSFSSolid
            Color: [206, 191, 242, 255]
            Outline:
                Style: esriSLSSolid
                Color: [110, 110, 110, 255]
                Width: 0 Label:
        Description: Transparency: 0
    Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field: null
Fields:
    FID ( type: esriFieldTypeOID , alias: FID )
    Shape ( type: esriFieldTypeGeometry , alias: Shape )
    OBJECTID ( type: esriFieldTypeInteger , alias: OBJECTID )
    COUNTRY ( type: esriFieldTypeString , alias: COUNTRY , length: 50 )
    CONTINENT ( type: esriFieldTypeString , alias: CONTINENT , length: 13 )
    ISO3A ( type: esriFieldTypeString , alias: ISO3A , length: 5 )
    ISO2 ( type: esriFieldTypeString , alias: ISO2 , length: 5 )
    Shape_Leng ( type: esriFieldTypeDouble , alias: Shape_Leng )
    Shape_Area ( type: esriFieldTypeDouble , alias: Shape_Area )
Supported Operations:   Query   Generate Renderer   Return Updates
AndyBurns
Yes, the featurelayer recreates the data in the browser, esentially doing a call to the rest endpoint to get the data you need and in turn instead of loading ''images'' from a normal dynamic service it loads data (in json normally) into the browser which gets stored in memory.
How much data is being asked of the feature layer? Do you use firebug to see the request going out to the service and the wait for the response?
Do you get any console errors?
vinayb
Thanks for reply ,
  We changed project system to WebMeractor now there is improvement in the performs in firefox and chrome but in IE it sill hangs.Below request always get timeout.There are about 220 polygons
http://10.32.9.106:6080/arcgis/rest/services/Administrative_Maps/World_Countries_v3_WMS_v1/MapServer...
