If statement for multiple feature layers infotemplate
3123
9
08-28-2013 10:42 AM
BarryGuidry
I have added two FeatureLayers to query attributes from in an infotemplate (popup). What I would like to figure out is how to write an if statement that states if one attribute is undefined ("SHELTER") to use another attribute field ("BUILDING"), and add to the following function. Is this possible?
function getTextContent(graphic) { //continuation of popup feature             var bldg = "<br /><br />Shelter: " +graphic.attributes.SHELTER + "<br /><br />Shelter Room: " +graphic.attributes.LOCATION; //fields, within the featureLayer, to return information for             return  bldg;         }
Or, another idea, is how to simply have it always query the top-most layer attributes? I think that would solve my problem as well.
BenFousek
FeatureLayer variable name
As in the layer itself or any of the layer's properties, functions, etc?
//the layer itself var layer = graphic.getLayer();  //the layer's id var layerId = graphic.getLayer().id;
function getTextContent(graphic) {   if (graphic.getLayer().id === 'feature_layer_one') {     //do stuff    } else if (graphic.getLayer().id === 'feature_layer_two') {     //do stuff    } }
You would need to set the feature layer's id on creation.
var fl = new esri.layers.FeatureLayer(url, {   mode: 1,   id: 'feature_layer_one' });
BenFousek
  if (graphic.attributes.SHELTER === undefined) {
    //do stuff
  } else {
    //do stuff
BarryGuidry
Thank you, Ben. That works except, as I expected, may display the "undefined" information first in a series of features to navigate in the popup. I would rather it display the attributes of the top-most layer of the feature selected instead. Any ideas?
BenFousek
I'm not exactly 100% on the workflow that get's you to getTextContent(graphic) or how undefined would be returned if you return something else when SHELTER is undefined.
BarryGuidry
Almost where I need to be with this:
            var bldg = "<br /><br />BUILDING: " +graphic.attributes.BUILDING; //fields, within the featureLayer, to return information for
   return bldg;
            } else {
   var bldg2 = "<br /><br />BUILDING: " +graphic.attributes.SHELTER + "<br /><br />Shelter Room: " +graphic.attributes.LOCATION;
   return  bldg2;
But, would also rather force the popup to auto navigate to the second record of the selected feature if SHELTER is undefined, in addition to displaying the attributes of the variable "bldg2" above. Is there a code snippet to navigate to the next record in an infotemplate popup?
BenFousek
BarryGuidry
//the layer itself
//the layer's id
    //do stuff
    //do stuff
  mode: 1,
Thats even better, Ben, but I still need to somehow have it navigate to attributes of 'feature_layer_one' first if it exists where clicked, and if non-existent, then navigate to 'feature_layer_two', as well, somewhere in the if statement that I have now (below).
   if (graphic.getLayer().id === 'fl') {
   var bldg = "<br /><br />BUILDING: " +graphic.attributes.SHELTER + "<br /><br />Shelter Room: " +graphic.attributes.LOCATION; //fields, within the featureLayer, to return information for
   return  bldg;
   } else if (graphic.getLayer().id === 'fl2') {
   return bldg;
Thanks again.
BenFousek
Is there a reason you don't just set the infoTemplate of the feature layer?
BarryGuidry
Yes Sir. I am pulling attribute data from two FeatureLayers, with one of the fields being the same name (for good reason; BUILDING).
VinayBansal
You can use select function of infoWindow to navigate to the index of feature
https://developers.arcgis.com/en/javascript/jsapi/popup-amd.html#select
