Clustering from a maps graphic layer
1382
08-19-2013 05:08 PM
AndrewDavis
I have a dynamically generated graphics layer which is populated from a large JSON.  I am able to add this to the map, without problem.
I want to take the same data.response object and use it to create either a heat map or a clustered graphics layer.
All of the examples I have worked with are using a query to a feature service.
Has anyone seen or worked with using a data object instead?
Andy
derekswingley1
The clustering sample loads a .json file and creates clusters from it.
AndrewDavis
Thanks for the reply..
I am looking at the page and it is one that I have used before.  I may be missing something here..
map.on("load", function() {
            domStyle.set(query("a.action.zoomTo")[0], "display", "none");
            var photos = esriRequest({
                "url": "data/1000-photos.json",
                "handleAs": "json"
photos.then(addClusters, error);
If my graphicLayer is a dynamically built layer that I already have on the map is there a call needed like above to a url where I would query the data?  (meaning the photos json object).  When I set the var 'photos' as equal to an esriRequest how would you give it a url if it is not available on my server, but is a returned data object from a solr query?
Andy...
