graphics, context menu, edit - can I rotate TEXT
4729
9
08-06-2013 05:55 AM
AdrianMarsden
Honored Contributor
Hi
I have a drawing toolbar that allows my users to add graphics.  Using this sample I have added context menu to edit the shapes they have drawn.  My users can add textsymbols (which have a point geometry) this part of the code
ctxMenuForGraphics.addChild(new dijit.MenuItem({
        label: "Rotate/Scale",
        onClick: function() {
            if (selected.geometry.type !== "point") {
                editToolbar.activate(esri.toolbars.Edit.ROTATE | esri.toolbars.Edit.SCALE, selected);
            } else {
                alert("Not implemented");
Prevents the rotate option being enabled for the textsymbol.
However my users want to be able to rotate textsymbols.  If I remove the check for POINTS in the code above I don't get the "Not implemented" warning, but I also don't get any rotate handles.
The TextSymbol does have a rotation property, so I could get that set when it is generated, but the user wil have to be good with angles.
Any thoughts?
ACM
BenFousek
Points only have move.  To rotate point symbols and text you have to use the symbol's angle property.
The angles can be confusing to users as you mentioned.  I've used a slider in a tooltip dialog, but I'm thinking about going towards menu options "Rotate 90° Clockwise", "Rotate 90° Counterclockwise", and "Rotate 180°".
AdrianMarsden
Honored Contributor
OK - reviving thread after 3.8 says this can be done.  I am trying now to merge the functionality into the context menu sample
https://developers.arcgis.com/javascript/jssamples/graphics_contextmenu.html
My code is Non-AMD so not sure if I can get this working.
Cheers
ACM
PS this is as far as I have got
        onClick: function () {
            if (selected.geometry.type !== "Point") {
                if (selected.symbol.declaredClass === "esri.symbol.TextSymbol") {
                    editToolbar.activate(esri.toolbars.Edit.EDIT_TEXT, selected);
                else {
            } else {
But it fails with Uncaught Error: [esri.toolbars.Edit::activate] Unable to activate the tool. Check if the tool is valid for the given geometry type.
JianHuang
non-AMD style should work.
You still need to specifically tell the edit toolbar to enable rotate.
function activateToolbar(graphic) {
        var tool = 0;
        tool = tool | esri.toolbars.Edit.MOVE;
        tool = tool | esri.toolbars.Edit.SCALE;
        tool = tool | esri.toolbars.Edit.ROTATE;
 tool = tool | esri.toolbars.Edit.EDIT_TEXT;
        //specify toolbar options
        var options = {
          //uniformScaling: false
        editToolbar.activate(tool, graphic, options);
AdrianMarsden
Honored Contributor
Mmm nearly there I think
I tweaked your code into mine, to give
                        var tool = 0;
                        var options = {
                        editToolbar.activate(tool, selected, options);
This doesn't produce any errors, but it doesn't give any resized or rotate handles - it doesm however allow a drag of the textsymbol.
Cheers
Adrian
JianHuang
Can you create a simple case and put it on jsfiddle?
AdrianMarsden
Honored Contributor
Odd - I created my own version(I have never got to frips with jsfiddle) and it worked OK -copied to jsfiddle  http://jsfiddle.net/EqVX6/2/  - right click the text and selct rotate on the text.
So, I guess there is something about how I add the text in my production site - I'll look at that next week.
AdrianMarsden
Honored Contributor
Hi -  I sent the Selected object to console in the working and non-working version - all I can see different is the projection
Working object
  • _extent: Object
  • _graphicsLayer: Object
  • _offsets: Array[1]
  • _shape: Object
  • attributes: undefined
  • geometry: Object
    • spatialReference: Object
      • wkid: 4326
      • __proto__: Object
    • type: "point"
    • x: -40
    • y: 35
    • __proto__: Object
  • infoTemplate: undefined
  • symbol: Object
    • _fill: null
    • _stroke: null
    • align: "middle"
    • color: b.Color
    • font: Object
    • horizontalAlignment: "center"
    • kerning: true
    • rotated: false
    • text: "Editable Text"
    • type: "textsymbol"
    • x: 0
    • xoffset: 0
    • y: 0
    • yoffset: 0
Failing object
  • _extent: Object
  • _shape: Object
  • attributes: Object
  • geometry: Object
      • wkid: 27700
      • __proto__: Object
    • type: "point"
    • x: 315910.97257876315
    • y: 85021.0373395566
    • __proto__: Object
  • symbol: Object
    • _inherited: Object
    • align: "middle"
    • angle: 0
    • color: b.Color
    • font: Object
    • kerning: true
    • rotated: false
    • text: "FAILING"
    • x: 0
    • xoffset: 0
    • y: 0
    • yoffset: 0
End of day here.  So off home 🙂
ACM
JianHuang
Just a little bit off topic. In my opinion, the context menu is very 'desktop' design, which may not be suitable for modern web application, especially for mobile devices.
AdrianMarsden
Honored Contributor
True - but for my internal application it is just right - I know exactly what my users use (currently XP, IE8 with Google Chrome Frame, monitors, keyboards and mice) - I'm not sure I'd ever want anyone doing this sort of stuff on a mobile device - I'd use Collector or the green app for that.
One difference between my test (on fiddle) and prod system, is the text isn't in the default map.graphics, but in a new graphics layer.
