I want to create a folder using an attribute value from a feature
2717
6
07-30-2013 04:34 AM
OLANIYANOLAKUNLE
This is my code and the error message received also
mxd = arcpy.mapping.MapDocument("Current") df = arcpy.mapping.ListDataFrames(mxd)[0] fc = "Parcels" field = "StateName" cursor = arcpy.SearchCursor(fc)  for row in cursor:  val = row.getValue(field) arcpy.CreateFolder_management("C:\\"+ "\\" + Str(val) + "\\")  Runtime error  Traceback (most recent call last):   File "<string>", line 1, in <module>   File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 14477, in CreateFolder     raise e ExecuteError: Failed to execute. Parameters are not valid. ERROR 000735: Folder Name: Value is required Failed to execute (CreateFolder).
Any suggestions?
MathewCoyle
Honored Contributor
Ah that is because that tool requires two parameters, the path and the folder name separate.
arcpy.CreateFolder_management("C:\\", str(val))
http://resources.arcgis.com/en/help/main/10.1/index.html#//0017000000pz000000
It would be easier to just use os.makedirs()
MathewCoyle
Honored Contributor
Str shouldn't be capitalized. Also string substitution would be the preferred method for these kinds of operations, which eliminates the need for the str operator at all.
arcpy.CreateFolder_management("C:\\{0}".format(val)
The way I create folders is using os.makedirs(). This creates all directories recursively if they do not exist which helps if you want to create folders where the parent folders may or may not exist.
OLANIYANOLAKUNLE
I still have the same error check it below:
>>> fc = "Parcels"
>>> field = "StateName"
>>> for row in cursor:
...     val = row.getValue(field)
>>> arcpy.CreateFolder_management("C:\\{0}".format(val))
MathewCoyle
Honored Contributor
OLANIYANOLAKUNLE
Thanks that works perfectly
OLANIYANOLAKUNLE
Please can you help me with this:
I want to create the following Nested folders i.e.
- StateName - arcpy.CreateFolder_management("C:\\", str(val))
- LGAName(DistrictName) this would be created inside the StateName Folder - arcpy.CreateFolder_management("C:\\", str(val),outName)
- PlotNo(BlockNo) this would be created inside the LGAName(DistrictName) Folder - arcpy.CreateFolder_management("C:\\", str(val)+ outName,outName1)
- arcpy.mapping.ExportToPDF(mxd,r"C:\\", str(val) + outName + "\\" + outName1 + "\\" + "Land Granted To " + outName2)
I'm having this "cant take more than two arguments issue especially with the last two create folder statements and the export to pdf statement
this was the script I used below
fc = "Parcels"
field = "OBJECTID"
field1 = "Plot_No"
field2 = "Block_No"
field3 = "Name_Allottee"
field4 = "TDP_Status"
field5 = "LGA"
field6 = "District"
field7 = "Shape.STLength()"
field8 = "SitePlan_Status"
for row in cursor:
#row.getValue(field)
   val1 = row.getValue(field1)
   val2 = row.getValue(field2)
   val3 = row.getValue(field3)
   val4 = row.getValue(field4)
   val5 = row.getValue(field5)
   val6 = row.getValue(field6)
   val7 = row.getValue(field7)
   val8 = row.getValue(field8)
outName = str(val5) + "_LGA" + "(" + str(val6) + "_Area" + ")"
outName1 = "Plot_" + str(val1) + "(" "Block_" + str(val2) + ")"
outName2 = str(val3) + " Block_" + str(val2) + "_Plot_" + str(val1) + "_" + str(val6) + "_Area_of_" + str(val5) + "_LGA" + ".pdf"
os.startfile(r"C:\\", str(val) + outName + "\\" + outName1 + "\\" + "Land Granted To " + outName2)
Kindly assist please. Thanks
MathewCoyle
Honored Contributor
