Georeferencing with Python?
1505
07-26-2013 09:24 AM
MichaelGlassman2
Is it possible for me to georeference a CAD file in ArcMap using Python? I know the projection, rotation angle, the X and Y shift distances, and the scale value.
JimCousins
You could use the information you have to create a CAD World file.
MichaelGlassman2
Would it be possible to use ArcPy to access/utilize the World File
JimCousins
Yes. You need to:
1) Create a new text file with the appropriate name in the same directory as the CAD file.
2) Use open(outputfilename, "w") to open the new text file for writing.
3) Write your information in the appropriate format a line at a time
4) Close your output file.
If you have never worked with file I/O:
http://en.wikibooks.org/wiki/Non-Programmer's_Tutorial_for_Python_3/File_IO
Regards,
Jim
