Closest Facility Service with Asynchronous Execution
2611
5
07-25-2013 05:15 PM
ShaunWeston
I've been trying to solve a closest facility task with asynchronous execution, but not having much luck so far. It's works fine for synchronous excecution
e.g. The below works fine on http://route.arcgis.com/arcgis/rest/services/World/ClosestFacility/NAServer/ClosestFacility_World
but not
http://logistics.arcgis.com/arcgis/rest/services/World/ClosestFacility/GPServer/FindClosestFacilitie...
// Push map click into incident parameter var features = []; features.push(location); var incidents = new esri.tasks.FeatureSet(); incidents.features = features; closestFacilityParams.incidents = incidents;   var inPoint = new esri.geometry.Point("1719868", "6047566", app.map.spatialReference); var location = new esri.Graphic(inPoint, configOptions.markerSymbol); var features = []; features.push(location); var facilities = new esri.tasks.FeatureSet(); facilities.features = features; closestFacilityParams.facilities = facilities;   closestFacilityTask.solve(closestFacilityParams, function (result) {    alert(result.routes.length); });
The reason I need use the async service is I have over 100 facilities.
ShaunWeston
Yeah I did manage to get it working. This is the function I used.
// Locate the closest feature function getClosestFeature(evt) {     // Setup the report progress bar and show it     $("#closestFeatureLoadBar").progressbar({         value: false     });     $("#closestFeatureLoadBar").show();       // Clear previous grpahics     app.map.graphics.clear();       // Get the map click point and add it as a location     var inPoint = new esri.geometry.Point(evt.mapPoint.x, evt.mapPoint.y, app.map.spatialReference);     var location = new esri.Graphic(inPoint, configOptions.markerSymbol);     // Add map click to map     app.map.graphics.add(location);     // Push map click into incident parameter     var features = [];     features.push(location);     var incidents = new esri.tasks.FeatureSet();     incidents.features = features;         // Get the facility features from the map service     var dataLayer = new esri.tasks.DataFile({         url: configOptions.facilitiesURL + "/query?where=1%3D1&returnGeometry=true&outFields=*&f=json"     });       // Setup the parameters for the closest facility     var closestFacilityParams = {         "incidents": incidents,         "facilities": dataLayer,         "cutoff": configOptions.cutOffTime,         "route_shape": "True Shape",         "populate_directions": true,         "directions_language": "en",         "directions_distance_units": "Meters",         "directions_style_name": "NA Desktop"     }       // Setup closest facility task     // If service is secure get token     var closestFacilityTask;     if (configOptions.closestFacilityService.secure === "true" || configOptions.closestFacilityService.secure === true) {         // Make the request         getToken(configOptions.closestFacilityService.tokenURL, configOptions.closestFacilityService.username, configOptions.closestFacilityService.password, function (token) {             closestFacilityTask = new esri.tasks.Geoprocessor(configOptions.closestFacilityService.url + "?token=" + token);             closestFacilityTask.outSpatialReference = app.map.spatialReference;             // Submit the closest facility tool task             closestFacilityTask.submitJob(closestFacilityParams, completeCallback);         });     }     else {         closestFacilityTask = new esri.tasks.Geoprocessor(configOptions.closestFacilityService.url);         closestFacilityTask.outSpatialReference = app.map.spatialReference;         // Submit the closest facility tool task         closestFacilityTask.submitJob(closestFacilityParams, completeCallback, taskFailed);     }       // When task is complete     function completeCallback(jobInfo) {         // If job completed successfully         if (jobInfo.jobStatus !== "esriJobFailed") {             // When route and directions returned             closestFacilityTask.getResultData(jobInfo.jobId, "output_routes", getRoute);             closestFacilityTask.getResultData(jobInfo.jobId, "output_directions", getDirections);         }             // If failed         else {             // Show the error message - Get from job info messages             alert(configOptions.errorMessageText + jobInfo.messages[6].description);         }         // Hide progress bar         $("#closestFeatureLoadBar").hide();           // Go back to identify mode         clickmode = 'identify';         changeCursor(clickmode);     }       // Get route result     function getRoute(result) {         // For each of the features returned         $.each(result.value.features, function () {             // Add facility to map             var layerOID = this.attributes.FacilityID;             var queryTask = new esri.tasks.QueryTask(configOptions.facilitiesURL);             var query = new esri.tasks.Query();             query.where = "OBJECTID = " + layerOID;             query.outSpatialReference = app.map.spatialReference;             query.returnGeometry = true;             query.outFields = ["*"];             queryTask.execute(query, function (results) {                 // For each of the results returned                 $.each(results.features, function () {                     var facility = new esri.Graphic(this.geometry, configOptions.markerSymbol);                     // Add point to map                     app.map.graphics.add(facility);                 });             });               // Add the route to the map             var route = new esri.geometry.Polyline(this.geometry);             var graphic = new esri.Graphic(route, configOptions.routeLineSymbol);             app.map.graphics.add(graphic);               // Zoom to feature and expand out extent             var extent = graphic.geometry.getExtent();             app.map.setExtent(extent.expand(configOptions.routeZoomBuffer));         });     }     // Get directions result     function getDirections(result) {         // For each of the features returned         var directionsText = "";         var count = 0;         $.each(result.value.features, function () {             var directions = this.attributes.Text;             var distance = Math.round(this.attributes.DriveDistance * 100) / 100;             var time = Math.round(this.attributes.ElapsedTime * 100) / 100;               // If not the first line then add paragraph and directions             if (count != 0) {                 directionsText = directionsText + "</br></br><B>" + directions + "</B>";                   // Add in distance and time if necessary                 if (distance > 0) {                     directionsText = directionsText + "</br>" + distance + " metres";                 }                 if (time > 0) {                     directionsText = directionsText + "</br>" + time + " minutes";                 }             }                 // Add starting text             else {                 directionsText = directionsText + "<B>Starting from your location</B>";             }             count = count + 1;         });           // // Populate and show info window - Desktop version         if (currentPage.indexOf("map") != -1) {             app.map.infoWindow.hide();             // Size of infoWindow             app.map.infoWindow.resize(configOptions.infowWindowSize[0], configOptions.infowWindowSize[1]);             app.map.infoWindow.setTitle("Directions");               // Set location of info window             var screenPoint = new esri.geometry.ScreenPoint((app.map.width / 1.5), (app.map.height / 2));               // Set info window content                        app.map.infoWindow.setContent("<div id='directionsContent'></div>");             $("#directionsContent").append(directionsText);             app.map.infoWindow.show(screenPoint, app.map.getInfoWindowAnchor(screenPoint));         }     } }
ShaunWeston
Ok because it's a GP service I think it needs to be implemented differently in the Javascript code. I've been looking through this:
http://resources.arcgis.com/en/help/arcgis-rest-api/#/Closest_Facility_Service_with_Asynchronous_Exe...
oes anyone have any samples where they've successfully consumed a AGS Online async network service with Javascript?
sameerpuppal
Hey Shaun,
Thanks to your sample I am able to use it for my routing with async call...it works well for 9 points but as soon as I use provide more than 9 points to async call... my calls starts through proxy. Did you face similar issue for more no. of points.
SakshiNigotia
Hey. Did you get the resolution for this?
ShaunWeston
KenBuja
MVP Esteemed Contributor
Shaun,
You should mark your post as the answer to the question.
