I have been trying to pull the sybtype domain information over and have run into what feels like a brick wall. Looking at the snippet below of what is listed in the REST:
"types": [
"id": 1,
"name": "Small_Service_Point",
"domains": {
"Service.GIS_CONVERSION_DELIVERY_AREA": {"type": "inherited"},
"Service.SUBTYPE_CODE": {"type": "inherited"},
"Service.LEAD_DIAMETER": {
"type": "codedValue",
"name": "Dom_Small_Service_Diameter",
"codedValues": [
"name": "5/8\"",
"code": 0.625
"name": "3/4\"",
"code": 0.75
I need to access the type (i.e. codedValue or inherited), then the codedValues and below.It seems that I should be able to access this under results.types.domains.type, results.types.domains.codedValues, and so on but it is not working. Here is a snippet of one of many, many failed tests...dojo.forEach(res.types, function(resTypes)
if (resTypes.id == fieldCodeGood)
console.log("There is a match to " + resTypes.name);
domsGood = resTypes.domains;
console.log(domsGood);
for (domFieldNames in domsGood)
console.log(domFieldNames);
if (domFieldNames.codedValues)
console.log("working");
else
console.log("not working");
else
console.log("NO match to " + resTypes.name);
The part where it's not working starts at for (domFieldNames in domsGood). I've tried dojo.forEach there and it won't even process. Based on other accesses to the REST it seems I should be able to retrieve these values similar to above but it's not working. The mapservice is unfortunately not a publicly accessible one and I'm failing to find an example that is at the moment. Any help that can be given would be greatly appreciated. Thank you in advance!
