ArcGIS 10 Pre-release Intersect Failure on Large Dataset
3149
06-21-2010 10:23 AM
MikeChancey
I have been testing 10 pre-release with some of our standard processes.  The only issue I have encountered has been with the interesect tool.  I am trying to intersect two polygon features, one representing parcels (193,569 records) and one representing impervious surfaces, (681,255 records).  This is a process that has run successfully in previous versions of ArcGIS.  I have tried using input files stored in file geodatabases, shapefiles, and even coverages.  I have run repair geometry on the input features.  No matter what I try the query errors out.
Reading Features...
Processing Tiles...
ERROR 999999: Error executing function.
Invalid Topology [Topoengine error.]
Failed to execute (Intersect).
Failed at Mon Jun 21 10:25:46 2010 (Elapsed Time: 14 minutes 55 seconds)
From another run the error log shows:
- <ResultViews>
- <ResultView Tool="Intersect">
  <CommandLine>Intersect_analysis 'C:\GeoProcessing\SWProcessing\SWGISData.gdb\swBilling\swImperviousSurfaces #;C:\GeoProcessing\SWProcessing\SWProcessFile.gdb\KCMO\swParcels_Process #' C:\GeoProcessing\SWProcessing\SWProcessFile.gdb\KCMO\swImperviousSurfaces_Split1 ALL # INPUT</CommandLine>
  <ToolSource>C:\Program Files\ArcGIS\Desktop10.0\ArcToolbox\Toolboxes\Analysis Tools.tbx\Overlay\Intersect</ToolSource>
  <StartTime>06/21/10 11:10:14 AM</StartTime>
- <Parameters>
- <Inputs>
  <Parameter Label="Input Features" Type="Dataset">C:\GeoProcessing\SWProcessing\SWGISData.gdb\swBilling\swImperviousSurfaces #;C:\GeoProcessing\SWProcessing\SWProcessFile.gdb\KCMO\swParcels_Process #</Parameter>
  <Parameter Label="JoinAttributes" Type="Scalar">ALL</Parameter>
  <Parameter Label="Output Type" Type="Scalar">INPUT</Parameter>
  </Inputs>
- <Outputs>
  <Parameter Label="Output Feature Class" Type="Dataset">C:\GeoProcessing\SWProcessing\SWProcessFile.gdb\KCMO\swImperviousSurfaces_Split1</Parameter>
  </Outputs>
  </Parameters>
- <Environments>
  <Environment Label="Precision For New Coverages">SINGLE</Environment>
  <Environment Label="Auto Commit">1000</Environment>
  <Environment Label="Minimize memory use during analysis on terrains">false</Environment>
  <Environment Label="Compression">LZ77</Environment>
  <Environment Label="Coincident Points">MEAN</Environment>
  <Environment Label="Random number generator">0 ACM599</Environment>
  <Environment Label="Raster Statistics">STATISTICS 1 1</Environment>
  <Environment Label="Level Of Comparison Between Projection Files">NONE</Environment>
  <Environment Label="Output has Z Values">Same As Input</Environment>
  <Environment Label="Maintain fully qualified field names">true</Environment>
  <Environment Label="Tile Size">128 128</Environment>
  <Environment Label="Pyramid">PYRAMIDS -1 NEAREST DEFAULT 75</Environment>
  <Environment Label="Default TIN storage version">CURRENT</Environment>
  <Environment Label="Output Spatial Grid 1">0</Environment>
  <Environment Label="Cell Size">MAXOF</Environment>
  <Environment Label="Output has M Values">Same As Input</Environment>
  <Environment Label="Output Spatial Grid 2">0</Environment>
  <Environment Label="Output Spatial Grid 3">0</Environment>
  <Environment Label="Maintain Spatial Index">false</Environment>
  <Environment Label="Precision For Derived Coverages">HIGHEST</Environment>
  </Environments>
- <Errors>
  <Error>ERROR 999999: Error executing function.</Error>
  <Error>Failed to execute (Intersect).</Error>
  </Errors>
  <EndTime>26 minutes 41 seconds)</EndTime>
  </ResultView>
  </ResultViews>
This process is mission essential, and has to work as a Python script.  So far I can't get it to work in the model builder window or even just straight from the toobox.
The error log mentions Output has Z Values and Output has M Values.  I am fairly sure neither input feature as either Z or M.
FWIW, the PC I am testing on sucessfully ran this process in 9.1, 9.2, 9.3, and 9.31.  We did do a fully reformat before installing 10 so there are no leftover bits of previous versions of ArcGIS.
Any ideas?
MikeChancey
Found my own answer on this one, read the system requirements first.  I had inadvertantly selected a PC that did not meet the minimums.  The specs require a dual core or better, mine was just a regular P4.  I uninstalled and moved it to an actual dual core unit and the large intersect worked quickly with no issues.
jiaxingcui
hehe    I have met this problem today. I think it's the problem that my computer dont have enough memory.
