Create a base map gallery list in a drop down button using AMD
4547
10
05-17-2013 12:11 PM
KenBuja
MVP Esteemed Contributor
I'm attempting to convert the example that Kelly wrote to add the basemap gallery basemaps to the map in a dropdown button into AMD. I'm running into a problem with getting the base maps added to the button. In this function, the ForEach loop fires, but the children aren't added. I've created a fiddler with the new code and original code commented out.
                         function createBasemapGallery() {                 var basemapGallery = new BasemapGallery({                     showArcGISBasemaps: true,                     map: map                 });                  connect.connect(basemapGallery, 'onLoad', function () {                     array.forEach(basemapGallery.basemaps, function (basemap)                          dom.byId('basemapMenu').addChild(new dijit.MenuItem({                             label: basemap.title,                             onClick: lang.hitch(this, function(){                                 this.basemapGallery.select(basemap.id);                             })                         }));                     });                 });             }
derekswingley1
Use dijit/registry.byId to get a reference to a dijit (in this case your dijit/Menu) and not dom.byId. Then use addChild on the object retuned by registry.byId. I also cleaned up the code and markup a little:  http://jsfiddle.net/rVM9Z/
derekswingley1
KenBuja
Thanks Derek!
by Anonymous User
Not applicable
Was just going to ask how to convert that basemap drop down menu sample to AMD, so glad you posted this!
by Anonymous User
Not applicable
I'm sorry to dig up this old thread, but if you're there, I am having a problem populating the basemap dropdown menu with a custom list of basemaps. The code works great when 'showArcGISBasemaps : true', but not when 'false' and I try to use my own list in the BasemapGallery. Here I make my custom list:
 // Create custom list of basemaps for the gallery
 var basemapsList = [];
 var basemapAerial = new Basemap({
  layers : [new BasemapLayer({
   type : "BingMapsAerial"
  title : "Aerial",
  thumbnailUrl : "images/bingMapsAerial.png"
 basemapsList.push(basemapAerial);
 var basemapHybrid = new Basemap({
   type : "BingMapsHybrid"
  title : "Hybrid",
  thumbnailUrl : "images/bingMapsHybrid.png"
 basemapsList.push(basemapHybrid);
And here I put it in the basemapGallery, but in this scenario, the dropdown is empty:
   showArcGISBasemaps : false,
   bingMapsKey : "example",
   basemaps : basemapsList,
   map : map
 basemapGallery.startup();
  connect.connect(basemapGallery, 'onLoad', function() {
   arrayUtils.forEach(basemapGallery.basemaps, function(basemap) {
    registry.byId('basemapMenu').addChild(new MenuItem({
     label : basemap.title,
     onClick : function() {
KenBuja
In my application, I added a custom base map to the dropdown list of ArcGIS basemaps with the following code
     map: map
var basemaps = [];
var chartsBMLayer = new BasemapLayer({
     url: "http://egisws02.nos.noaa.gov/ArcGIS/rest/services/RNC/NOAA_RNC/ImageServer"
var chartBaseMap = new Basemap({
     layers: [chartsBMLayer],
     title: "NOAA Charts",
basemaps.push(chartBaseMap);
basemapGallery.add(chartBaseMap);
basemapGallery.on("load", function () {
     for (i = 0; i < basemapGallery.basemaps.length; i++) {
          (function (x) {
                    label: basemapGallery.basemaps.title,
                    onClick: function () {
                         basemapGallery.select(basemapGallery.basemaps.id);
          }(i));
by Anonymous User
Not applicable
Thanks for that Ken, I still get the blank drop down if I choose to not show the ArcGIS basemaps. Basically I am trying to not show any of the gallery's default basemaps by hiding them. I think I must have messed up some snippet of code while copying and pasting, because this worked when I tried it in a title pane.
by Anonymous User
Not applicable
This is the whole shebang, btw (editor, navigation and basemaps):
require(["esri/config", "esri/map", "esri/dijit/BasemapGallery", "esri/dijit/Basemap", "esri/dijit/BasemapLayer", "esri/dijit/editing/Editor", "esri/layers/FeatureLayer", "esri/tasks/GeometryService",
"esri/toolbars/draw", "esri/toolbars/navigation", "dojo/on", "dijit/registry", "dojo/keys", "dojo/parser", "dojo/_base/array", "dojo/i18n!esri/nls/jsapi", "dijit/form/Button", "dijit/Menu", "dijit/MenuItem",
"dojo/dom", "dojo/_base/connect", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane", "dijit/Toolbar", "dijit/DropDownMenu", "dojo/domReady!"],
function(esriConfig, Map, BasemapGallery, Basemap, BasemapLayer, Editor, FeatureLayer, GeometryService, Draw, Navigation, on, registry, keys, parser, arrayUtils, i18n, Button, Menu, MenuItem, dom, connect) {
 parser.parse();
 //snapping is enabled for this sample - change the tooltip to reflect this
 i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
 i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
 esriConfig.defaults.geometryService = new GeometryService("http:/.../Geometry/GeometryServer");
 var map = new Map("map", {
  basemap : "topo",
  center : [-98, 39],
  zoom : 4,
  slider : false
 // Have to combine the basemap gallery and edit 'on load' functions
 map.on("layers-add-result", initEditing);
 var operationsPointLayer = new FeatureLayer("http://.../test/FeatureServer/0", {
  mode : FeatureLayer.MODE_ONDEMAND,
  outFields : ["*"],
  opacity : .50
 map.addLayers([operationsPointLayer]);
 map.infoWindow.resize(400, 300);
 function initEditing(event) {
  // This is a test of syntax to ONLY edit the CDB layer
  var featureLayerInfos = [{
   'featureLayer' : operationsPointLayer
  var settings = {
   map : map,
   createOptions : {
    polygonDrawTools : [esri.dijit.editing.Editor.CREATE_TOOL_RECTANGLE]
   // Try referencing just the CDB layer, is this what layerInfos needs?
   layerInfos : featureLayerInfos
  var params = {
   settings : settings
  var editorWidget = new Editor(params, 'editorDiv');
  title : "Bing Aerial",
  title : "Bing Hybrid",
 var basemapTopo = new Basemap({
   url : "http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"
  title : "Topographic",
  thumbnailUrl : "images/topo.jpg"
 basemapsList.push(basemapTopo);
 var basemapUSATopo = new Basemap({
   url : "http://services.arcgisonline.com/ArcGIS/rest/services/USA_Topo_Maps/MapServer"
  title : "USA Topo",
  thumbnailUrl : "images/usa_topo.jpg"
 basemapsList.push(basemapUSATopo);
  showArcGISBasemaps : true,
  //bingMapsKey : "test",
  map : map
 // Add the basemap gallery in drop down menu on toolbar
 basemapGallery.on("load", function() {
  createBasemapGallery();
  for ( i = 0; i < basemapGallery.basemaps.length; i++) {( function(x) {
      label : basemapGallery.basemaps.title,
    }(i));
 //Navigation tools
 navToolbar = new Navigation(map);
 registry.byId("zoomin").on("click", function() {
  navToolbar.activate(Navigation.ZOOM_IN);
 registry.byId("zoomout").on("click", function() {
  navToolbar.activate(Navigation.ZOOM_OUT);
 registry.byId("pan").on("click", function() {
  navToolbar.activate(Navigation.PAN);
 registry.byId("deactivate").on("click", function() {
  navToolbar.deactivate();
JeffPace
i wonder
you require has connect (including contentpane, bordercontainer, etc..) but it is not in your function.
Double check your syntax and make sure you are aliasing properly
by Anonymous User
Not applicable
Funny, it was the 'loaded' property phrasing for the BasemapGallery. Instead of:
I needed to use:
if (basemapGallery.loaded) {
