Erase Function does not work after simplification
1027
05-09-2013 10:31 AM
paulgoldenstern
My erase function does not work after I simplify a polygon.
The simplified polygon will not work as the erase feature. It will work prior to simplification, or any other polygon will work.
I am using:
Arc Map 10.0 (arc Info license)
I Simplified the polygon using bend simplify,  with a reference baseline of 300 meters. I have tried this as both a shapefile or a file geodatabase feature. Projections are the same for data frame, input feature, and erase feature.
