python errors
1565
04-29-2013 05:54 AM
daisysparla
I'm working on mine final internship en thesis. And working for the first time with pythonwin.
I'm trying to make the python script work but i'm getting a lot of errors. I'm using pythonwin (2.6)
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 309, in RunScript
    debugger.run(codeObject, __main__.__dict__, start_stepping=0)
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\debugger\__init__.py", line 60, in run
    _GetCurrentDebugger().run(cmd, globals,locals, start_stepping)
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\debugger\debugger.py", line 624, in run
    exec cmd in globals, locals
  File "T:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\no_value_DS.py", line 69, in <module>
    arcpy.ASCIIToRaster_conversion(Blok_asc, ASCIITo_asc9, "INTEGER")
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\conversion.py", line 1615, in ASCIIToRaster
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000885: Input ASCII raster file: t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_input/'s does not have a file extension.
ERROR 000876: Output raster: t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\workspace\Blok_asc.asc's extension is invalid for the output raster format.
Failed to execute (ASCIIToRaster).
Is there anyone who can help me with this? If you need more information, let me know:)
Daisy
JakeSkinner
Esri Esteemed Contributor
Hi Daisy,
Can you post your code?  Don't forget to wrap it in CODE tags (using the # above).
daisysparla
# import arcinfo
# Import arcpy module
import arcpy
from arcpy import env # Analysis environment
from arcpy.sa import *
arcpy.env.overwriteOutput = True #enable output
# Import sys, os, glob modules
import sys
sys.path.append('C:/Python26/ArcGIS10.0/Lib/')
import os
import glob
# Set Geoprocessing environments
env.scratchWorkspace = "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\workspace/"
env.workspace = "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\workspace/"
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# inputdir
inDir = "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_input/"
OutDir = "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_output/"
OutDir2 = "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_output2/"
# scan files to process
fileList = glob.glob(inDir + "pt*.asc")
# filename starts at
fileStart = fileList[0].rfind('\\')+1
#loop
for inPut in fileList:
    print("processing " + inPut[fileStart::1])
#input
    inPutWater =    inDir + inPut[fileStart::1]
    outPut =        OutDir + "water_goed" + inPut[fileStart+2:-4:1]
    outPut2 =        OutDir2 + "water_fout" + inPut[fileStart+2:-4:1]
# Script arguments
    Blok_asc = arcpy.GetParameterAsText(3)
    if Blok_asc == '#' or not Blok_asc:
        Blok_asc = "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_input/"
    Select_no_value_area = arcpy.GetParameterAsText(0)
    if Select_no_value_area == '#' or not Select_no_value_area:
        Select_no_value_area = "\"GRIDCODE\"  = 1" # provide a default value if unspecified
    Area = arcpy.GetParameterAsText(1)
    if Area == '#' or not Area:
        Area = "10 Unknown" # provide a default value if unspecified
    Select_areas_ = arcpy.GetParameterAsText(2)
    if Select_areas_ == '#' or not Select_areas_:
        Select_areas_ = "\"F_AREA\" > 40" # provide a default value if unspecified
# Local variables:
#    ASCIITo_01301 =             env.workspace + "/Blok_asc.asc"
    Output_raster =             env.workspace + "/ASCIITo_asc9.asc"
    ASCIITo_asc9 =              env.workspace + "/Blok_asc.asc"
    RasterT_IsNull_2_shp =      env.workspace + "/Output_raster.shp"
    RasterT_IsNull_1_Select =   env.workspace + "/Select_no_value_area.asc"
    Output_Feature_Class__2_ =  env.workspace + "/RasterT_IsNull_1_Select.shp"
    Output_Feature_Class =      env.workspace + "/Output_Feature_Class__2_.shp"
# output
    Output_Feature_Class__3_ = OutDir + "/output.shp"
# Process: ASCII to Raster
# Process: Is Null
    arcpy.gp.IsNull_sa(ASCIITo_asc9, Output_raster)
# Process: Raster to Polygon
    arcpy.RasterToPolygon_conversion(Output_raster, Block_asc, "NO_SIMPLIFY", "VALUE")
# Process: Select
    arcpy.Select_analysis(Block_asc, RasterT_IsNull_1_Select, Select_no_value_area)
# Process: Calculate Areas
    arcpy.CalculateAreas_stats(RasterT_IsNull_1_Select, Output_Feature_Class__2_)
# Process: Select (2)
    arcpy.Select_analysis(Output_Feature_Class__2_, Output_Feature_Class, Select_areas_)
# Process: Eliminate Polygon Part
    arcpy.EliminatePolygonPart_management(Output_Feature_Class, Output_Feature_Class__3_, "AREA", Area, "0", "CONTAINED_ONLY")
    if isEmpty(Output_Feature_Class__3_):
        arcpy.Copy_management(Output_Feature_Class__3_, outPut, "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_output/")
    else:
        arcpy.Copy_management(Output_Feature_Class__3_, outPut2, "t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_output2/")
JakeSkinner
Hi Daisy,
I believe the problem is with your directory paths.  When using a backslash, specify 'r' in front of the path.  For example, change your paths from:
to:
r"t:\U12002_Afstuderen_Daisy_en_Tiemco\Praktijk_water]\Test_1_DS\No_value_areas\Py_input"
Also, you will want to remove the ending forward slash.
daisysparla
There was someone in my office who know how to fix the errors.
But thank you for responsing en your help!
