Using AMD, connect throws an error.
2238
6
04-23-2013 08:29 AM
JimWharton
I'm attempting to connect to the map's onLoad event:
var map;       require(["esri/map", "esri/SpatialReference", "esri/geometry/Extent", "dojo/_base/connect", "app/populate", "dojo/ready"],         function(Map, SpatialReference, Extent, connect, populate, ready) {           ready(function() {             var initialExtent = new Extent({               xmax: -11241653.995873693,               xmin: -13198441.919973679,               ymax: 5178320.359930991,               ymin: 4453085.835561435,               "spatialReference": {                 "wkid": 102100               }});              map = new Map("mapDiv", {               extent: initialExtent,               basemap: "streets"             });              connect(map, "onLoad", function() {               populate.addPoints();             });           });        });   }
No matter what, I keep getting a JS error:
Uncaught TypeError: Object is not a function.
I've tried replacing the call to populate.addPoints() with a simple console.log, and still, it errors on "connect". That's a pretty basic Dojo thing, so I'm confused about where the problem is. The examples page shows something nearly identical.
derekswingley1
Use connect.connect() instead of connect().
The dojo/_base/connect module is not a single function but rather contains a couple of functions. For more detailed examples, look at the Dojo 1.7(AMD) section here:  https://dojotoolkit.org/reference-guide/1.7/dojo/connect.html
derekswingley1
JimWharton
Excellent, that works. The docs may need a tweak to represent that gotcha.
Thanks!
-Jim
derekswingley1
You're welcome!
Where in the docs do we use connect()? It should be dojo.connect or connect.connect everywhere.
JimWharton
You're welcome!
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/map-amd.html#onLoad
All examples on that page.
I appreciate your help.
-Jim
derekswingley1
Thanks Jim, we'll get those fixed.
KenBuja
MVP Esteemed Contributor
Any update on when this will be fixed?
At the same time, could you also update the API reference so that the "AMD Module Require" version of the documentation shows "on" method in the code snippets and the new event names?
