Error Create New Site ArcGIS SERVER 10.1
2870
5
04-11-2013 10:19 AM
WesleyAntal2
I installed the ArcGIS Server 10.1 in Linux Fedora 6 x64 (Path: /home/arcgis/server), but when I try to create a new site in Manager ArcGIS Server, this error occurs:
Failed to create the site. Failed to create the service 'System/CachingTools.GPServer'.
The Link http://support.esri.com/en/knowledgebase/techarticles/detail/40398 of support not working, because my path is /home/arcgis/server.
What's happen?
thanks.
JustinRodriguez
Justin, the archive "hosts" have just one line:
::1     arcgis    localhost
where "arcgis" is name of machine.
Other Idea?
thanks
Thank you for the update.
Please make it say this exactly:
127.0.0.1 localhost.localdomain localhost
Just copy and paste it. Comment out the line you have in there currently. That most likely is the cause of the issue. Thanks-
JustinRodriguez
What's happen?
thanks.
This issue is commonly caused by incorrect settings in your etc/hosts file. Clear everything out of your etc/hosts file except an entry that reads something like:
If you do not want to delete anything, then please simply comment any other items out with an '#'. Let me know if that works. Thanks-
Justin
WesleyAntal2
Justin
Other Idea?
thanks
JustinRodriguez
Other Idea?
thanks
WesleyAntal2
WORKED...
Thanks Justin.
BubbaHey
Justin is da man!
