Directions Widget Text Selection
1693
5
04-08-2013 07:29 AM
MarkHoover
Trying to implement the new Directions Widget and noticed an odd trait.  If I have an address typed into the text boxes and then double-click or triple-click (to select a word or select all, respectively) inside of it, no text is selected.  Worse, I can't even click and drag my cursor over part of the text to select it.  I just have to put my cursor somewhere and hit Delete/Backspace until it's all gone.  Is this a property I can configure?  This behavior is present in the samples, as well.  (Also, am I just going crazy, or is the Directions Widget not currently in the API reference?)
KellyHutchins
Esri Notable Contributor
Try setting directions._dnd.skipForm to true. Here's an example:
        directions = new esri.dijit.Directions({           map: map         },"dir");                  directions.startup();         directions._dnd.skipForm = true;
KellyHutchins
This is a known issue with the widget and will be fixed in the next release of the JSAPI (version 3.5).
Kelly
MarkHoover
Is there a workaround for this currently?  Otherwise this widget is effectively useless to us until API v3.5.  Also, am I correct that there is currently no API Reference doc for this dijit?
KellyHutchins
JohnGravois
the API reference for the Directions widget can be found here.  it will be visible through browsing shortly.
MarkHoover
Perfect, thanks to both of you!
