Server error Export Web Map with Bing Maps
1784
04-05-2013 01:09 PM
BenFousek
I'm using the JSAPI and with a default Export Web Map GPServer using custom templates. The application has been deployed and working properly for a while. Then today I started getting the following server error when bing maps are included in the Web Map as JSON:
Layer "ve": Unable to connect to Microsoft Bing service. Authentication failed. Failed to execute (ExportWebMap). Failed to execute (Export Web Map).
Any ideas on this would be appreciated.
nicogis
try read 'Bing Maps Use in ArcGIS Has Changed'
