Spatial Query
1749
03-05-2013 03:23 PM
RobertPincus
I want to select a polygon in one layer, run a spatial query on another layer and list the attributes of the selected features.
For example, using the service at "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/", I can select the State of California's feature (layer 5). I then want to take this feature and run a spatial query on the Counties layer (layer 3) and list the names of the selected counties.
Robert
TracySchloss
Honored Contributor
The first query function finds the geometry, which is then passed to another querytask, this one based on geometry as a search instead of by attributes.  In my example, I am using region, but you should be able to follow the logic.  I have a dropdown list instead of a text input field to make sure the input is valid.
function findRegion(){         var e = document.getElementById("regionSelect");  //the component name of the region selection         var regionQueryTask = new esri.tasks.QueryTask("http://myserverpathName/ArcGIS/rest/services/myService/MapServer/3");         var regionQuery = new esri.tasks.Query;         regionQuery.text = e.options[e.selectedIndex].text;//this is my primary display field  if you needed another field, use a where clause         regionQuery.returnGeometry = true;         regionQueryTask.execute(regionQuery,showRegionResults);     }
The result function of the initial query finds the geometry of the feature that is selected in findRegion
function showRegionResults (results) {         region = results.features[0].geometry;         map.setExtent(region.getExtent(), true);  //zooms to the region         findFeatureInRegion(region);     }  function findFeatureInRegion(region) {    var newQueryTask = new esri.tasks.QueryTask("http://myserverpathName/arcgis/rest/services/myService/MapServer/2"); //EUSstaff    var newQuery = new esri.tasks.Query;    newQuery.outFields = ["*"];    if (region) {    newQuery.geometry = region;    newQuery.spatialRelationship = esri.tasks.Query.SPATIAL_REL_CONTAINS;    newQueryTask.execute(newQuery);  dojo.connect(newQueryTask, "onComplete", function(results){  //whatever you wanted to do with the features that were selected in the 2nd query } }
RahulMetangale1
Hi Robert,
This can be done with two spatial queries:
1. query the state using the map click point.
2. use the result of first query(state polygon) to query the counties layer
I hope this helps.
Rahul
RobertPincus
I have seen the code examples that do what you suggest.
The way I want to go is to start the selection process by entering a state name in a text box.
And I can select a state by entering the state name in a text box.
My problem is getting the code that will create a spatial query on another layer.
Robert
TracySchloss
Honored Contributor
RobertPincus
This works. Thanks.
Robert
