Display multiple diagrams in single map using schematics js api
1123
03-05-2013 12:33 AM
AbdulMateen
i have multiple diagrams generated ,how to display all diagrams in one map,?
or as user generates new diagram immediatly the new diagram must append to previous diagram side by side
i can display single diagram using
following
var diagUrl=http://testserver/arcgis/rest/services/elecDataKma/MapServer/exts/SchematicsServer/diagrams/0-030015...
var myDynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(diagUrl);
  map.addLayer(myDynamicMapServiceLayer);
Note: I tried by two methods but could not get
1. added multiple diagurl  to map but the diagrams are overlapping
2.i tried to use definiation query on mxd  also the diagrams are overlapping
your suggestions are higly appreciated.
AbdulMateen
Anyone from ESRI  can support this thread?
AbdulMateen
Hi Rick,
I tried all ways but no solution
its urgent can you suggest as soon as possible.
AbdulMateen
It is solved ,
using custom methods, after generating the diagram just use the relative move method to repostion the features inside the diagram.
