HiI have a bit of code using ESR's Javascript API for GoogleMaps as below:Whenever I click on a point which has been taken from my ArcGIS Server instance It give me the specified fields returned in the usual googlemaps bubble. The map is being used as part of a form for reporting faults so I could essentially do with the information in the bubble going into a field in the form which can then be submitted with the rest of the form as normal.I hope that makes sense<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html debug=true>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>DH Test - Return Data from ArcGIS Server</title>
<script src="http://maps.google.com/maps?file=api&v=2&key=AIzaSyC2qROCcqJ_yZbBRaojMmNSgc-cIByJrac"type="text/javascript"></script>
<script src="http://serverapi.arcgisonline.com/jsapi/gmaps/?v=1.6" type="text/javascript" ></script>
<script type="text/javascript">
var gmap = null;
var qtask = null;
var query = null;
var mapExtension = null;
var gOverlays = null;
function initialize() {
// GMap construction
gmap = new GMap2(document.getElementById('gmap'));
gmap.addMapType(G_NORMAL_MAP);
gmap.addMapType(G_SATELLITE_MAP);
gmap.addControl(new GLargeMapControl());
gmap.addControl(new GMapTypeControl());
gmap.setCenter(new GLatLng(53.5167, -1.1333), 10);
gmap.enableScrollWheelZoom();
//Create MapExtension utility class
mapExtension = new esri.arcgis.gmaps.MapExtension(gmap);
// Query Task
qtask = new esri.arcgis.gmaps.QueryTask("http://gisfusinternet/ArcGIS/rest/services/GoogleTest/MapServer/0");
// You can execute a task and listen for the complete event or use the callback to get the results
GEvent.addListener(qtask, "executecomplete", function() {
//console.debug("'query task complete' event fired!!!");
// Query
query = new esri.arcgis.gmaps.Query();
function executeQuery() {
var bounds = gmap.getBounds();
// clear map overlays and event listeners using MapExtension removeFromMap
mapExtension.removeFromMap(gOverlays);
// set query parameters
query.queryGeometry = bounds;
query.returnGeometry = true;
query.outFields = ["SYMLINK", "UNITNO"];
// execute query task
qtask.execute(query, false, mycallback);
function mycallback(fset) {
//JS literal class esri.arcgis.gmaps.OverlayOptions
var overlayOptions = {
strokeColor:"#FF0000",
strokeWeight:3,
strokeOpacity:0.75,
fillColor:"#000066",
fillOpacity:0.4
//JS literal class esri.arcgis.gmaps.InfoWindowOptions without tabs
var infoWindowOptions = {
content:"<p>UNITID = <b>{SYMLINK}</b></br>Column Number = <b>{UNITNO}</b></p>"
gOverlays = mapExtension.addToMap(fset,overlayOptions,infoWindowOptions);
</script>
</head>
<body onload="initialize();" onunload="GUnload();">
<table width="100%" height="100%">
<tr>
<td align="center">
<table>
<tr align="left">
<td>
<input type="button" value="Execute Query" onclick="executeQuery();" />
<input type="button" value="Clear Map Overlays" onclick="mapExtension.removeFromMap(gOverlays);" />
</td>
</tr>
<tr align="left" valign="top">
<td>
<div id="gmap" style="width: 500px; height:500px;"></div>
</td>
</tr>
</table>
</td>
</tr>
</table>
</body>
</html>
