Feature to raster, loop for model builder
953
5
02-21-2013 07:07 AM
MarceloOyuela
I'm trying to make a model for feature to raster.
The feature has 12 columns named for each month of the year. The values ??????for each month are precipitation amount.
I want to convert the features to raster using a  model but can not find the way to make it automatic. The result would be 12 rasters representing precipitation for the month selected.
My problem its: the "field" parameter in the feature to raster tool, how can i use iterator for columun or  theres another way?
Thanks for the help.
Marcelo Oyuela
JakeSkinner
Esri Esteemed Contributor
Hi Marcelo,
You could accomplish this using python.  Here is an example:
import arcpy
fc = r"C:\raster\polygon.shp"
list = ["January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"]
for month in list:
    arcpy.FeatureToRaster_conversion(fc, month, r"C:\raster\precipitation_" + month + ".tif")
MarceloOyuela
Hi Marcelo,
import arcpy
for month in list:
Thank you very much, work very good.
Question: can i do this as a model in model builder?.
Thank you again
JakeSkinner
Yes, you can actually add a python script to a model.
MarceloOyuela
ok, But, I want to know how to make a model that can do the same process. What iterator type should I use?
JakeSkinner
I don't believe this will be possible without writing a script.
