Adding Shapefile
2852
02-06-2013 08:51 PM
VEERUTALREJA
Hello, I was actually trying to add a shapefile on the map. I was looking at this sample
http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/#sample/portal_addshapefile
but unfortunately this sample does not work..The code is broken I guess because it gives an error when i try to run the live sample and when I upload a zipped shape file,It says" shp file missing". I think there is some issue with the code in the sample.
Can anyone help me and let me know how can I get it to work. I really appreciate the help.
Thank you
Veeru
SunilPalkar
Hi Veeru,
Its working fine..I tried at my end..
Please let me know your code..You can put your code  in JS Fiddle
VEERUTALREJA
<!DOCTYPE HTML>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9">
    <title>Add Shapefile</title>
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css">
    <script>var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/"></script>
    <script>
      dojo.require("esri.map");
      dojo.require("esri.layers.FeatureLayer");
      dojo.require("esri.dijit.Popup");
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.ready(init);
      var map;
      var portalUrl = "http://www.arcgis.com";
   function init() {
        esri.config.defaults.io.proxyUrl = "/arcgisserver/apis/javascript/proxy/proxy.ashx";
  esri.config.defaults.io.alwaysUseProxy = false;
        dojo.connect(dojo.byId("uploadForm").data, "onchange", function (evt) {
          var fileName = evt.target.value;
  //filename is full path in IE so extract the file name
          var arr = fileName.split("\\");
          fileName = arr[arr.length - 1];
          if (fileName.indexOf(".zip") !== -1) {//is file a zip - if not notify user
            generateFeatureCollection(fileName);
          }else{
            dojo.byId('upload-status').innerHTML = '<p style="color:red">Add shapefile as .zip file</p>';
        //create a popup to replace the map's info window
       // var popup = new esri.dijit.Popup(null, dojo.create("div"));
   var extent = new esri.geometry.Extent({"xmin": -82.982664376928,"ymin":36.9701097164086,"xmax":-77.3635190912301,
            "ymax":40.8546687287403,"spatialReference":{"wkid":4326}});
       //map = new esri.Map("mapDiv", { extent: esri.geometry.geographicToWebMercator(extent)});
          basemap: "streets",
    extent:extent
      function generateFeatureCollection(fileName) {
        var name = fileName;
        //Chrome and IE add c:\fakepath to the value - we need to remove it
        //See this link for more info: http://davidwalsh.name/fakepath
        //name = name[0].replace("C:\\fakepath\\","");
        dojo.byId('upload-status').innerHTML = '<b>Loading </b>' + name;
        //Define the input params for generate see the rest doc for details
        //http://www.arcgis.com/apidocs/rest/index.html?generate.html
        var params = {
          'name': name,
          'targetSR': map.spatialReference,
          'maxRecordCount': 1000,
          'enforceInputFileSizeLimit': true,
          'enforceOutputJsonSizeLimit': true
        //generalize features for display Here we generalize at 1:40,000 which is approx 10 meters
        //This should work well when using web mercator.
        var mapextent = esri.geometry.getExtentForScale(map,40000);
        var resolution = mapextent.getWidth() / map.width;
        params.generalize = true;
        params.maxAllowableOffset = resolution;
        params.reducePrecision = true;
        params.numberOfDigitsAfterDecimal = 0;
        var myContent = {
          'filetype': 'shapefile',
          'publishParameters': dojo.toJson(params),
          'f': 'json',
          'callback.html': 'textarea'
  console.log(myContent);
        //use the rest generate operation to generate a feature collection from the zipped shapefile
          esri.request({
     url: portalUrl + '/sharing/rest/content/features/generate',
          content: myContent,
          form: dojo.byId('uploadForm'),
          handleAs: 'json',
          load: dojo.hitch(this, function (response) {
            if (response.error) {
              errorHandler(response.error);
              return;
            dojo.byId('upload-status').innerHTML = '<b>Loaded: </b>' + response.featureCollection.layers[0].layerDefinition.name;
            addShapefileToMap(response.featureCollection);
          error: dojo.hitch(this, errorHandler)
      function errorHandler(error) {
        dojo.byId('upload-status').innerHTML = "<p style='color:red'>" + error.message + "</p>";
      function addShapefileToMap(featureCollection) {
        //add the shapefile to the map and zoom to the feature collection extent
        //If you want to persist the feature collection when you reload browser you could store the collection in
        //local storage by serializing the layer using featureLayer.toJson()  see the 'Feature Collection in Local Storage' sample
        //for an example of how to work with local storage.
        var fullExtent;
        var layers = [];
        dojo.forEach(featureCollection.layers, function (layer) {
          var infoTemplate = new esri.InfoTemplate("Details", "${*}");
          var layer = new esri.layers.FeatureLayer(layer, {
            infoTemplate: infoTemplate
          //associate the feature with the popup on click to enable highlight and zoomto
          dojo.connect(layer,'onClick',function(evt){
            map.infoWindow.setFeatures([evt.graphic]);
          //change default symbol if desired. Comment this out and the layer will draw with the default symbology
          changeRenderer(layer);
          fullExtent = fullExtent ? fullExtent.union(layer.fullExtent) : layer.fullExtent;
          layers.push(layer);
        map.addLayers(layers);
        map.setExtent(fullExtent.expand(1.25), true);
        dojo.byId('upload-status').innerHTML = "";
      function changeRenderer(layer) {
        //change the default symbol for the feature collection for polygons and points
        var symbol = null;
        switch (layer.geometryType) {
        case 'esriGeometryPoint':
          symbol = new esri.symbol.PictureMarkerSymbol({
            'angle':0,
            'xoffset':0,
            'yoffset':0,
            'type':'esriPMS',
            'url':'http://static.arcgis.com/images/Symbols/Shapes/BluePin1LargeB.png',
            'contentType':'image/png',
            'width':20,
            'height':20
          break;
        case 'esriGeometryPolygon':
          symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([112, 112, 112]), 1), new dojo.Color([136, 136, 136, 0.25]));
          break;
        if (symbol) {
          layer.setRenderer(new esri.renderer.SimpleRenderer(symbol));
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" dojotype="dijit.layout.BorderContainer" style="width:100%; height:100%;">
      <div dojotype="dijit.layout.ContentPane" id="rightPane">
        <div style='padding-left:4px;'>
          <p>
            Add a zipped shapefile to the map.</p><p>Visit the
            <a target='_blank' href="http://help.arcgis.com/en/arcgisonline/help/#/About_shapefiles/010q000000m2000000"/>About Shapefiles</a> help topic for information and limitations.</p>
              <form enctype="multipart/form-data" method="post" id="uploadForm">
              <div class="field">
                  <label class="file-upload">
                      <span><strong>Add File</strong></span>
                      <input type="file" name="file" id="inFile" />
                  </label>
              </div>
              </form>
              <span class="file-upload-status" style="opacity:1;" id="upload-status"></span>
              <div id="fileInfo"> </div>
        </div>
    </div>
    <div id="mapDiv" style="height:500px; width:500px; border:1px solid black"></div>
  </div>
</body>
</html>
This is the code that I have used...
The JSfiddle for the link is given below...
http://jsfiddle.net/veeru1984/QNQuC/2/
Let me know...
Veeru Talreja
