Cursor Hover Style Over DynamicMapService
2073
6
02-06-2013 02:58 AM
MattFancher
I want the cursor style to change from the default to a pointer when the user hovers over features drawn in an ArcGISDynamicMapServiceLayer.  Currenty I'm accomplishing that by using a transparent FeatureLayer with the same extent as the DynamicMapServiceLayer.  I use the onMouseOver and onMouseOut events of the FeatureLayer to change the MapCursor property of the map appropriately.  Is there a better way to do that?  Thanks in advance.
Map URL:
http://maps.puc.state.oh.us/esa/index.asp
derekswingley1
I would say that's the way to go. I'd be curious if anyone else around here has alternative ideas.
Looking at your site, I think the method you're using works well. Are you seeing any issues with the current approach?
MattFancher
I think the performance degrades with the FeatureLayer included.  I notice the effect when zoomed in close.  The infoWindow does not respond as quickly and the map navigation gets jerky.  I don't see that behavior when I remove the FeatureLayer.  I tried simplifying the geometry of the data source for the FeatureLayer, but that didn't seem to help, or at least didn't solve the problem entirely.  Maybe I need to simplify it further.  In any case, thanks for the response.  It's good to know I'm at least on the right track.
derekswingley1
Which browser and zoom level? The app works well for me when I'm zoomed in pretty close in Chrome.
You shouldn't need to simplify your features, the feature layer does this on the fly by default (for ONDEMAND mode, which you're using) relative to the map scale. More info on this in the "Feature Generalization" section here:  http://help.arcgis.com/en/webapi/javascript/arcgis/jshelp/#best_practices_feature_layers
StephenLead
Honored Contributor
+1, it looks great.
But why duplicate things by showing both feature and dynamic layers - why not remove the dynamic layer and just use the feature?
MattFancher
Derek - I was using IE9 zoomed in to level 14 and closer.  Sometimes I'd click and the infoWindow would popup.  Sometimes I'd click a few times and not get anything.  I can't consistently reproduce the problem though.  Maybe you are right and there isn't one.  Thanks for the tip about feature layer generalization.  I didn't know that.
Stephen - That is a good question.  The short answer is because I did not know how to create the same cartographic effect with a feature layer.  But if that is the way to go, then I'll take another look.  Thanks for the advice.
MattFancher
Stephen - Looks like the "why not" may be a matter of performance.  I tried using a feature layer alone, while maintaining the same symbology, and the draw time suffers.  The feature layer has yet to draw at all in IE9.
http://maps.puc.state.oh.us/esa/index2.asp
The draw time is better in Chrome and Firefox, but still slow.  Am I doing something wrong?  Thanks.
