What format of date to send in json in addFeature rest interface
5134
9
02-06-2013 12:54 AM
MatejSkerjanc
i'm sending all kind's of dates
1970-01-01 06:10:20.0000000 and it fails,...actually all but dot delimited date fail. For instance 1999.1.1. works but the result date in the database is always 1970-01-01 0x:xx:xx.0000000
The question is in what format do i have to send the date in to the addFeatures function
Thank you for the help
ManojrajTeli
I am not sure about it but you can try this in javascript and pass to addfeature
Date.parse(YourDate);
this statement actually passes the in some format in which they take base as 1 jan 1970 and above feature gives a 13 digit string of numbers
Manojraj Teli
ManojrajTeli
Manojraj Teli
MatejSkerjanc
Dear Manojraj Teli
the results 'm getting with this are odd numbers but indeed it works! The only problem is it changes 1970.1.1. to something in the lines of 1969.x.x
Did you ever get this behavior?
ManojrajTeli
Not exactly but in our apple Map App it was returning this value and also for our custom tooltip is was giving same format issue so had to convert it back.
MatejSkerjanc
it seems to be deducting one hour or so..will investigate out later further.
Thank you!
DianaBenedict
In Javascript I have been able to use Date().valueOf() to return primitive value of the current date.  I found that other options were yielding odd results and using the valueOf required much less coding/formating.
 var newDate = new Date().valueOf();
You can look at other date functions but I believe the issue has to do with the UTC format .. or something like that. If someone has an explanation or a different option that would be great.
MatejSkerjanc
Diana the valueOf returns the same result as without the value for me. Or am i well possibly doing something wrong.
DianaBenedict
I just stepped through my code and it looks like the date values are returned as follow:
newDate = 1360353562367
var newDate = new Date(); (without the ,valueOf() )
newDate = Fri Feb 8 13:09:05 MST 2013
In my case, if I do not set the date to .valueOf() I get an exception or sometimes it just converts it to weird cases.  However, I found that when use the .valueOf the date gets converted to the UTC format. Again, I am not sure if this is the best implementation but it seems to work on my system - I am able to insert a new feature with a date stamp.
Sometimes, I oticed that I needed to do a complete refresh and empty out all cache by selecting <ctrl> <F5> when I initially load the page; just to make sure that everything is all a new ... just a hunch though. I found that the world of web development really has a lot of external unknowns. Good luck!
MatejSkerjanc
Hmm i'm passing in my own date as parameter...anyhow thank you both, you've been most helpful.
MatejSkerjanc
I found the answer to the problem of losing one hour. As assumed the problem is in local date time type
http://stackoverflow.com/questions/2587345/javascript-date-parse
and a solid link http://blog.dygraphs.com/2012/03/javascript-and-dates-what-mess.html
