Legend Widget -- Layers added dynamically
1163
01-29-2013 03:21 PM
GregKnight
Hi all,
Are there any examples out there that illustrate the logic associated with using the Legend Dijit with layers that are added to the map after the map is instantiated?  All the examples seem to focus on displaying legends for layers that are known at runtime.  In my application the layers are not necessarily known at runtime.  Specifically, I am having some difficulty with the logic associated with
1) initializing the legend at runtime when its possible that no operational layers are loaded
and
2) later refreshing (or starting) the legend with (ad-hoc) operational layers that are added after the map is initially loaded
Are there any examples out there of this nature?  If not, could someone provide an outline of the logic necessary here?
Many thanks,
Greg
KellyHutchins
Esri Notable Contributor
Hi Greg,
The legend widget has a refresh property that you can use to update it with new layer information. Here's an example that shows how to refresh the legend with  new layer info.
http://jsfiddle.net/vguu3/
ShreyasVakil
I don't know if you have already seen this sample, but it does update the legend dynamically when we update the visibility of layers.
Legend - toggle services
GregKnight
Hi Shreyas,
Yes, I have seen that sample.  In that sample, the layers are known at runtime however -- and their layerInfo is pushed into an object which is passed to the legend dijit when it is instantiated.
var quakeLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/EarthquakesFromLastSevenDays/MapServer",{id:'quakes'});
legendLayers.push({layer:quakeLayer,title:'Earthquakes'});
var fireLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/MapServer",{id:'fire'});
legendLayers.push({layer:fireLayer,title:"Fire"});
Functionally, this is similar to what Im looking for, but I dont have the luxury of knowing the layerInfo at runtime.  What would I do in this case?
Many thanks,
Greg
BTW -  I love the updates to the JS API pages...  fantastic!
KellyHutchins
Hi Greg,
GregKnight
Hi Kelly,
That definitely helps.  Ill revisit my code later today.
Thank you,
Greg
