I think Feature Layer should reproject on-the fly. I did a quick test and was able to add layers from WKID: 4269 & 4326 on top of web mercator. Check the code below:<!doctype html> <html lang="en"> <head> <meta charset="utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/nihilo/nihilo.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" /> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } body{ background-color: #fff; overflow:hidden; font-family: sans-serif; } label { display: inline-block; padding: 5px 5px 0 5px; font-weight: 400; font-size: 12pt; } #header { padding-top: 4px; padding-right: 15px; color: #444; font-size:16pt; text-align:right;font-weight:bold; height:55px; background: #fff; border-bottom: 1px solid #444; } #subheader { font-size:small; color: #444; text-align:right; padding-right:20px; } #header, #subheader { text-shadow: 1px 1px 1px #cee1f0; filter: dropshadow(color=#cee1f0, offx=1, offy=1); } #rightPane{ margin: 0; padding: 10px; background-color: #fff; color: #421b14; width: 180px; } .ds { background: #000; overflow: hidden; position: absolute; z-index: 2; } #ds-h div { width: 100%; } #ds-l div, #ds-r div { height: 100%; } #ds-r div { right: 0; } #ds .o1 { filter: alpha(opacity=10); opacity: .1; } #ds .o2 { filter: alpha(opacity=8); opacity: .08; } #ds .o3 { filter: alpha(opacity=6); opacity: .06; } #ds .o4 { filter: alpha(opacity=4); opacity: .04; } #ds .o5 { filter: alpha(opacity=2); opacity: .02; } #ds .h1 { height: 1px; } #ds .h2 { height: 2px; } #ds .h3 { height: 3px; } #ds .h4 { height: 4px; } #ds .h5 { height: 5px; } #ds .v1 { width: 1px; } #ds .v2 { width: 2px; } #ds .v3 { width: 3px; } #ds .v4 { width: 4px; } #ds .v5 { width: 5px; } /* make all dijit buttons the same width */ .dijitButton .dijitButtonNode, #drawingWrapper { width: 160px; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.form.Button"); dojo.require("esri.map"); dojo.require("esri.layers.FeatureLayer"); var theGraphic = ""; //default for graphic/text var map = null; var highlightLayerText function init() { esri.config.defaults.io.proxyUrl = "http://svakil/JSProxyPage/proxy.ashx"; esri.config.defaults.io.alwaysUseProxy = false; var initialExtent = new esri.geometry.Extent({"xmin":-14788424.73638572,"ymin":3302079.621918744,"xmax":-11657564.057825731,"ymax":5552385.734633734,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: initialExtent, wrapAround180: true }); dojo.connect(map, 'onLoad', function() { dojo.connect(dijit.byId('map'), 'resize', map, map.resize); }); var url = "http://services.arcgisonline.com/ArcGIS/rest/services/Ocean_Basemap/MapServer"; var tiledLayer = new esri.layers.ArcGISTiledMapServiceLayer(url, { "id": "Ocean" }); map.addLayer(tiledLayer); featureLayer = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/0", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); map.addLayer(featureLayer); featureLayer1 = new esri.layers.FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ["*"] }); map.addLayer(featureLayer1); } dojo.ready(init); </script> </head> <body class="nihilo"> <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;"> <div id="map" class="shadow" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div> </div> </div> </body> </html>
