how to properly implement Open Transport Map
2468
8
01-07-2013 11:26 AM
NigelAlford
I've worked through the example (which is broken) and can't seem to properly pull the Open Streetmap layers as a web tiled layer.  In the example the server is returning back a 404 error, which leads me to believe that the service call or address has been updated by open transport maps.
This is the address given in the sample from Open Transport Maps
 http://[abc].tile2.opencyclemap.org/transport/${z}/${x}/${y}.png
Here's my non-working attempt:
 var sub = ["a","b","c"];
            var wtl = esri.layers.WebTiledLayer;
            var cycleMap = new wtl("http://{subDomains}.tile2.opencyclemap.org/transport/${z}/${x}/${y}.png",
                "id": "OTranspoMap",
                "copyright": "OTM",
                "subDomains": sub
map.addLayer(cycleMap);
I'm getting this error:
Uncaught TypeError: Cannot call method 'toString' of undefined
I've been searching around and haven't found anyone else with this question, but sorry if this is a repost.
JeffJacobson
In your format string try changing {subDomains} to {subDomain}.
NigelAlford
I tried that change and received the same error
JeffPace
http://${subDomain} (singular)
"subDomains":
in the JSON
NigelAlford
 var cycleMap = new wtl("http://${subDomain}.tile2.opencyclemap.org/transport/${z}/${x}/${y}.png",
                "copyright": "OTM",
                "subDomains": sub
Is this a jquery function? if so I'll try adding the jquery library in the beginning
NigelAlford
When I run the sample code, the tiles are not being found has anyone else seen this?
var cycleMap = new wtl("http://${subDomain}.tile.opencyclemap.org/cycle/${level}/${col}/${row}.jpg", {
          "copyright": "Open Cycle Map",
          "id": "Open Cycle Map",
          "subDomains": ["a", "b", "c"]
JeffJacobson
I was able to get it to work: https://github.com/WSDOT-GIS/OsmTilesInArcGisJS.
JeffPace
It works fine, except it only has PNG tiles.  change the url to png and it works.
NigelAlford
@jacobsj and @jeff.pace
Thanks for the help guys I was off by such a small amount...gotta love it
