Hide SubLayer from AGSJS TOC
723
01-07-2013 03:40 AM
CraigMcDade
I have a service with two layers. Using the AGSJS TOC widget is there a way to hide one layer from the TOC (not the map), while still keeping the 2nd layer in the service within the TOC and able to be turned on and off?
NianweiLiu
You can try using CSS styles, find the node id for that layer, then hide it in CSS. Not 100% dynamic, but easy to implement.
NianweiLiu
