ArcGIS Server Javascript API, JQuery, Dojo, WCF Services ?
4510
12-28-2012 07:31 AM
DeminHu
I am  learning ArcGIS Server JavaScript API, trying to develop a samll application, I need to consume a WCF service ( I have a feature class with related table, one-to-many, I need to view and  edit the related table by selecting features on the map).
I could find many samples  to consuming WCF with JQuery, but not dojo, in my company, the other teams are using JQuery except me, because I am using ESRI technologies.
I wonder if there are some sample codes: ArcGIS server Javascript API with  Dojo and WCF services.  if somebody knows, please kindly let me know.
Thanks.
JeffPace
There are a few other threads on this.  Just because the esri api is built on dojo does not require you to use it.
I use both jQuery and Dojo in my application, based on what the need is.  I use dojo for widgets, and jQuery for dom manipulation.
Just load jquery as a library and have at it.
DeminHu
Thanks you so much!! I will try that.
Be honest, it is  a little diffcult  for a beginner to learn both JQuery and Dojo, and get job done in a very limited time
JeffJacobson
I would use the esri.request method to consume the WCF services.
RavindraSingh
Hi Demin Hu,
May be you have solved your problem by this time. .Hope this link will help you out.
https://www.sitepen.com/blog/2011/01/13/using-the-dojo-toolkit-with-microsofts-wcf/
