Dojo AMD and creating instance of esri classes
1708
12-15-2012 09:01 PM
RahulMetangale1
Hi All,
I wanted to know in following code why we have to instantiate map as new esri.Map() and not as new myMap()
define(["dojo/_base/declare", "core_library/_Widget", "esri/map"], function (declare, WidgetBase, myMap) {      return declare([WidgetBase], {         _map: null,          postCreate: function () {             this._map = new esri.Map(this.domNode, { extent:initExtent,slider: true });                      }     }); });
ReneRubalcava
Esri Frequent Contributor
As of right now there are still parts of the API that are not fully AMD, as in they don't all return an object. The map is still one of these. It provides "esri/map" in it's define method and has a dojo.provide("esri.map"). A lot of the API has been updated since 3.0 to return objects via AMD, but not completely yet. I'm sure it's a big task on their end.
JohnnyPenet
As you showed here, myMap will be created but with empty parameters by AMD, which is not usefull and will fail because a node is mandatory, you need a node as you showed in the postCreate.
If you want to create a new class you must replace "esri/map" by [esri/map] and remove myMap from the list of arguments)
It is not clear the purpose of "core_library/_Widget"
Hi All,
        _map: null,
RahulMetangale1
Thank you the replay.
core_library/_widget is superclass from which following class is derived. it has some additional functions which i am using it for some other purpose.
I am still not clear on why it is not possible to use local variable to instantiate map.  Let me rephrase my questions again,
define(["dojo/_base/declare", "core_library/_Widget", "esri/map","dijit/form/Button"],
function (declare, WidgetBase, myMap,Button) {
        _map: null,
                 where Button is a local varibale.Now we can use new Button() to instantiate button
                 instead of new dijit.form.Button()
  var myButton = new Button({
                                      label: "Click me!",
                                      onClick: function(){}
                                      }, "someNode");
 but for map although we have local variable named myMap,following does not work
            this._map = new myMap(this.domNode, { extent:initExtent,slider: true });
        //following works
     this._map=new esri.Map(this.domNode, { extent: initExtent, slider: true });
ReneRubalcava
RahulMetangale1
Thank you!
