Detect Map Pan/Zoom based on User's Touch/Pinch
8480
13
12-14-2012 12:15 PM
AaronConnolly
Is it possible with the SDK to discern the difference between programmatically panning/zooming the map and one actually touching and pinching the map?
I need to be able to tell the difference with my app.
1. Listening for the 'MapDidEndPanning' and 'MapDidEndZooming' event does not tell you whether or not the user panned/zoomed the map or whether or not you did so programmatically.
2. AGSMapViewTouchDelegate only provides methods for click, tap + hold, tap + hold + release, and tap + hold + move.
- Aaron
NimeshJarecha
Any word from you guys (ESRI) as to whether hooking up gesture recognizers is recommended or not?
No, it is not recommended to hooking up gesture recognizers. If you do so then it'll interfere the functionality of map. In current SDK, there is no easy way to differentiate between programmatically panning/zooming the map and one actually touching and pinching the map. However, the next version of the SDK will have that functionality.
Regards,
Nimesh
AaronConnolly
I'm thinking I'm going to have to hook up my own gesture recognizer for both panning and pinching. Has anyone else faced this problem?
AaronConnolly
Piece of cake:
In view did load:
// Add gesture recognizers to map view
UIPanGestureRecognizer *panGestureRecognizer = [[UIPanGestureRecognizer alloc] initWithTarget:self action:@selector(mapPannedByTouch:)];
UIPinchGestureRecognizer *pinchGestureRecognizer = [[UIPinchGestureRecognizer alloc] initWithTarget:self action:@selector(mapPinchedByTouch:)];
[self.mapView addGestureRecognizer:panGestureRecognizer];
[self.mapView addGestureRecognizer:pinchGestureRecognizer];
Then:
- (void)mapPannedByTouch:(UIGestureRecognizer*)gestureRecognizer {
    NSLog(@"map panned by touch!");
- (void)mapPinchedByTouch:(UIGestureRecognizer*)gestureRecognizer {
    NSLog(@"map pinched by touch!");
AaronConnolly
After hooking up these gesture recognizers I notice that the map doesn't pan but a little bit after each pan. It looks like it might be conflicting with some of the map's default functionality.
- Aaron
AaronConnolly
Hey guys,
I noticed that if you add the gesture recognizer code to the MapViewDemo project the map doesn't work. You can't pan or zoom the map afterward. Why is that? Incidentally I found this post that describes how to bubble touch events up from the map. Does this work? If so, why can't we use gesture recognizers instead?
http://forums.arcgis.com/threads/38228-How-to-catch-AGSMapView-touch-gestures
- Aaron
AaronConnolly
After further investigation it seems you have to subclass AGSMapView and implement the touchesEnded event to do this. It is not clear, why, the gesture recognizers disable the map? Can we get clarification there?
NimeshJarecha
Regards,
Nimesh
AaronConnolly
Regards,
Nimesh
Got it. Thanks Nimesh.
FrankLin1
By the way , when can we meet next version of the SDK ?
Frank
NimeshJarecha
The new version of ArcGIS SDK for iOS is available now.
Regards,
Nimesh
