Unable to Export To Feature Class In Model Builder
1006
12-06-2012 05:06 AM
MarkYoung
I have a model whereby I wish to import an sde table, create xy events and export to a feature class. For some reason it says:
ERROR 999999: Error executing function.
Underlying DBMS error [ORA-01795: maximum number of expressions in a list is 1000
] [GAZMAN.LLPG_BLPU][STATE_ID = 61588]
The index passed was not within the valid range.
DBMS table not found [ORA-00942: table or view does not exist
] [CORPDATA.LLPG_Logical1][STATE_ID = 61608]
Failed to execute (Export XY Events To FC).
when it tries to export to a feature class. I know the feature class exists but what is the max number of expressions in a list - does that mean the max amount of attributes it can export?
Thanks in advance,
Mark
MichaelHarty
Mark,
Did you resolve your issue? I am having a similar problem when I try to import a .csv to convert it to a feature class in the model builder.  I can create an xy event layer, but the copy features tool fails and says
Not sure what this means.
Michael
MarkYoung
Morning Michael,
I think what I ended up doing here was to recalculate the spatial index. If you right click over the feature class and select properties, click on the index tab then recalculate in the spatial index section that may work. I am not sure why but every now and then I have to recalculate the spatial indexes of feature classes..
Hope that helps
Mark
MichaelHarty
Thanks a lot, Mark.  Problem solved
