identifyTask with editorWidget
905
11-29-2012 04:48 AM
danbecker
have a simple map where you can toggle ArcGISDynamicMapServiceLayer "base data" on/off.
the map also has a point/polygon/line featureService that is editable.
Everything works, when you click on a featureService point, the attribute inspector enables users to edit attributes, the featureTemplate allows users to create new points/lines/polys.
I now have a request to enable identifyTask on the base data, I used this example:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
which replaces map infoWindow with esri.dijit.Popup. The identify works, all feature.attributes are returned, ect...but the popup is only displayed when I click on a featureService point/poly/line. The attribute inspector popup is also gone, replaced by teh esri.digit.popup.
Any idea how to handle this?
BC
I am dealing with similar issue -
IdentifyTask using Popup template on two dynamicservicelayers and editing a feature layer using TemplatePicker.  IdentifyTask works but I cannot get editing part work.  Please post if you have found a solution.  Tnx.
