javascript html5 tabbed popup
1180
11-27-2012 08:09 AM
PaulMcBride
I'm trying to create a interactive map that is designed for urban planning to show zoning codes and restrictions.  within the feature popup I am wanting to have tabs for the type of information available such as general standards, permitted uses, special uses, and all standards.  Does anyone have experience with customizing a popup window in this way?
Thank you!!!
SteveCole
Honored Contributor
Have a look at this sample.
It's primary purpose is to demonstrate how to use dojo charts with popups but the sample also shows you an example of using a tabbed container within a popup.
PaulMcBride
Thank you for the information!  That will work and I can change the source code as needed from there.
